    Raspberry Pi helpful information, WLAN setup
    DSF Development
    • JoergS5
      JoergS5 last edited by JoergS5
      I don't know where to put this information, so I make a new thread, maybe someone has useful hints about Raspberry also to add here.
      I had some effort to activate WLAN with my Raspberry Pi 4 (first generation Pi 4). My Router was detected in the WLAN list and logging in gave no error message, but I did not get an IP address and it took about 10 minutes until I could connect to the internet. I tried everything, but at last I found the solution in hint https://hackaday.com/2019/11/28/raspberry-pi-4-hdmi-is-jamming-its-own-wifi/
      My display resolution is not the one which is mentioned in the link.
      I used channel 1 (2412 MHz). After changing the router to channel 2 (2417) it now works absolutely smoothly and connects immediately.
      With Raspi 3B I did not have this problem.
        I believe that issue (and a few others) have been solved with a firmware update for the pi4.
        See here to check your version and how to update: https://www.raspberrypi.org/documentation/hardware/raspberrypi/booteeprom.md
        I didn't have the wifi issue myself, but I did note a temp drop after updating.
        I believe most recent Pi4s should already have the newer versions, but there's probably a lot of older ones from release still out there.
        JoergS5 1 Reply Last reply Reply Quote 0
        • JoergS5
          JoergS5 @Phaedrux last edited by JoergS5
          @Phaedrux Thank you for your information. The issue was driving me crazy, because seeing the SSID, but not connecting... I tried dozens of different configurations.
          One good thing it had - I know the Raspberry a bit better again.
            Report back on whether the update made an improvement or not. I thought I had read that it had been addressed but looking through the release notes I didn't notice anything specific to that.
            • JoergS5
              @Phaedrux Will take a while because I'm working on the optical encoder with Raspi. The 8MP camera is good enough to get a pixel resolution of 1.2 μm, so I try to get a good endstop.
