DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1
I believe he's saying, "start a job, and then close DWC".
Yes, I tried that. SSH only, no VNC, no DWC. Still locked within a few minutes.
@Danal said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
Yeah that was it. I wanted to make sure it wasn't DWC related. I've been running RC10 + 2.1.1 and printing fine but I don't use the DWC.
Something to try... The systemd service file for the DCS was changed to set
CPUSchedulingPolicy=fifo CPUSchedulingPriority=20 which may be contributing to the problem.
Edit
/lib/systemd/system/duetcontrolserver.service
and remove those 2 lines, then reboot and see if that helps. -
@gtj0 said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
Edit /lib/systemd/system/duetcontrolserver.service and remove those 2 lines, then reboot and see if that helps.
Will do. I've made a bunch of other changes, so let me re-verify the hangs are real, then I will try that. THANKS!
I'm a little late to the reporting; to help confirm, I too have seen full system lock ups and print connection losses too with RRF 3.01-R10, DWC 2.1.5 and DSF 2.1.1.
I was able to overcome and get working with:
sudo system duetcontrolserver restart No system hardware changes, ribbons, or otherwise, just the new Beta install.
The duetcontrolserver would go to 400% CPU usage, and painstakingly getting to the terminal (I have screen direct on my Pi) was able to get a terminal open and issue the fix. SSH & web access were dead - couldn't remote in.
After the duetcontrolserver restart, system will work but still get random disconnects. I will try the modification above and report back too.
Well... just finished a two hour print, no changes, completed OK.
I will keep data points coming, in either direction.
Another fantastic build.
It is like playing the lottery. Sometimes works fine, other times loads of disconnections from DWC and/or error messages like "homing failed" or heaters take forever to turn on!
Back to RRF3.01_RC3!!!!
@chas2706 Are you experiencing this specific issue?
Which issue are you refering to because there are many.
Has anyone tried to upload a new slicer gcode with this version because when I do it the DWC only gives me access to the folders on the SBC!! -
@chas2706 said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
i suspect he was, in a slightly more diplomatic tone, trying to say unless you have something constructive to add to the issue in this particular forum topic you might be well advised to go elsewhere looking for some cheese to go with that whine.
yes there are a bunch of issues, and you're not the only one thats frustrated, but how you deal with it is only up to you.
i think you should take a page or two out of your own book..
@bearer said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
Ok cheers. Won't bother posting anything anymore bye bye.
Well I got the Pi back, I can get into SSH, I wiped the SD card with the image and instruction found here >>
[https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3]
I used the duetpi (with GUI).
And it does NOT work, can't find a config.g anywhere in it, even if I add one it doesn't work.
When connecting to the web page it sits there connecting, an error message bottom right states DCS not available.
systemctl reports both DCS and DWC as Active and Running. Log report in uploaded file.
Please make an SD card image available that works. It would be kind of nice if such an image existed for each RC, a list of files and their correct locations would also help enormously, it really shouldn't need to be this difficult.
@Garfield The SD card image has the "stable" versions of the DSF and needs the "unstable" versions OR you need to downgrade your Duet3 to the firmware located on the card image.
@Garfield said in DCS Crash with 3.01-R10 / DWC 2.1.5 / DSF 2.1.1:
Unfortunately, that is not anywhere near as easy as it sounds. The software on the SD has to match the firmware on the board well enough for them to talk. There are so many variants that a ton of images might actually become more confusing than not. Over time, this will all get better as 'apt update' and 'apt upgrade' get better and better at keeping everything in sync.
But... right now today, because you chose to "force" the card into a given state, by wiping and re-etching, then the burden also falls on you to "force" the board into a matching state, via bossa.
Step 1 is to get to get duetsoftwareframework on the SD to a whatever level you prefer.
sudo apt list duetsoftwareframework -a
Will show you all available levels, as well as what is installed.
sudo apt remove duetsoftwareframework sudo apt -s autoremove (-s is simulate, be sure it is removing what you want, then run it again without the -s) sudo apt install duetsofwareframework=1.3.2 (or whatever you want)
Will put everything at a certain level.
Step 2 is to bossa with the file found at /opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin This ensures that the SD and the board firmware will match.
P.S. I prefer to bossa from the Pi itself. Instructions are on the dozuki.
P.P.S When picking the release you want in step 1... At this moment, I know of no way to correlate "duetsoftwareframework release x.y.z" to "firmware V3.01 RCxyz". I'm working on finding a way. -
I did NOT choose to - I was given no option because I could not start / access the system hardwired or otherwise !!
I have no desire to fall out over this, the code is RC after all, you expect glitches but things just really shouldn't be this difficult, I should NOT need to use BOSSA - another mechanism is required because I have ZERO intention of making up yet more cables.
Same principle as the Pi would be optimal - blank SD card, formatted FAT32, firmware image in root - same way a huge amount of embedded systems are updated - it isn't difficult.
In an ideal world you shouldn't have to no; but it is what it is, hopefully you can switch back to the stable package feed soon and stop dealing with the unstable stuff in the near future.
If you can run bossa from the pi
wget https://pastebin.com/raw/Wa1kYf3G -O - | tr -d "\r" | bash
takes care of everything from downloading and building bossa to flashing the binary that was downloaded when you installed the reprapfirmware package.Script will also send the Duet3 to the bootloader if it has a working reprapfirmware so shouldn't have to deal with jumpers unless something is really wrong.
btw its just a plain micro usb cable needed. (with the caveat of avoiding multiple power supplies and potential ground loops - using the pi that is powered from the Duet is a convient way to achieve that)
@Garfield The only cable you should need for this is a standard USB-micro USB and using the instructions @bearer just posted.
If your particularly averse to this for whatever reason, you could make an SD to run the D3 in standalone mode and then just use either DWC to drag/drop the new firmware or use a USB cable and your favourite terminal program to run
M997 S0
(might want to check that, but I think that's right). Either way, there are a few options. That said, it'd probably be better to make threads and report the issues you're having so they can be addressed...? Other than one annoying bug with filaments, RC9 worked well for me. Have you got a list of issues you were having? -
I'm not averse - and should be up again soon, I'd really like to help with such problems and contriobute but right now the learning curve is pretty steep and what I think should be simple tasks seem not to be - and I do this **** for a living !! - I haven't coded in 20 years - got a team to do that ..... I'm back in learning mode here and I'm an old dog ....
....................... but right now the learning curve is pretty steep and what I think should be simple tasks seem not to be - and I do this **** for a living !!
My God, what chance do us mere mortals have! As far as I'm concerned, you guys are all talking in some foreign language that I don't understand. I'll be sticking with stand alone operation for quite some time yet methinks.
BOSSA .... No device found on /dev/ttyACM0 .....
could just mean you have to use the erase jumper after all; it'd be interesting to see what
lsusb
says before and after applying the erase jumper.(maybe i should get around to finishing the version that checks the /sys/bus/usb/ tree for usb id's to avoid such a vague error)
