    Ender5pro, Duet2WiFi Slow by slicer
    • Daniel
      Daniel last edited by
      Guys,
      Setting the Duet 2Wifi has being fun. Tons of experience and learning in the forums. I have made ll the mistakes in the book but made new friends correcting them.
      Now that I am ready to print, Cura and Simplify are conspiring against the RepRap flavor
      I am attaching below the Cura settings (4.06 version) for and Ender 5 RepRap
      I am not sure about all this M201, 202, 203 204 205
      On the right of the screen there is a series of offsets for the printing head, where are those used?
      My config.g is just below...Thanks
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Apr 19 2020 17:01:43 GMT-0400 (Eastern Daylight Time)
      M550 P"Daniel Ender 5 Duet 2 Wifi" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M92 X80.00 Y80.00 Z779.00 E409.00 ; set steps per mm
      M566 X900.00 Y900.00 Z24.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z900.00 E3600.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
      M906 X850 Y850 Z850 E850 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X220 Y220 Z300 S0 ; set axis maxima
      M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P9 C"zprobe.in" H5 F120 T12000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-45 Y3 Z2.235 ; set Z probe trigger value, offset and trigger height
      M557 X15:160 Y15:200 S20 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 A88.4 C265.5 D2.0 S1.00 V23.9 B0 ; disable bang-bang mode for the bed heater and set PWM limit (Values copied from auto tune D corrected from 0.9 to 2 by Phaedrux)
      M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S300 ; set temperature limit for heater 1 to 300C
      M307 H1 A390.6 C153.8 D3.5 S1.00 V23.9 B0 ; disable bang-bang mode for heater and set PWM limit (Values copied from auto tune)
      M563 P0 S"E3D V6 Nozzle X" D0 H1 F0 ; define tool 0
        The print head settings i THINK may come into play when doing one part at a time printing where it will print an entire part before moving onto the next (as opposed to printing a single layer of all the parts). It tells the slicer how big the print head is so it knows how far away to stay from the printed part. I'm not totally sure because I've never actually printed like that.
        remove the M201, m203, m204, m205 commands. They were probably a part of the printer profile that was loaded. Not applicable to the Duet.
        REsetting flow and feed rate can stay.
        The G28 and stay. You can add G29 S1 if you want to load a heightmap.
        The extruder bits are to prime the nozzle and can stay as well.
        That should solve the speed problem.
        Daniel 1 Reply Last reply Reply Quote 0
        • Daniel
          Daniel @Phaedrux last edited by
          @Phaedrux Thanks Phaedrux. I am flying now.
