    DWC connection denial
    Firmware installation
    57
    • iains
      iains last edited by
      I have just installed the Duet2 WiFi on my Delta printer. I have followed methodically the "Getting Connected Steps" My hurdle is getting past step 9. The board connects via USB and YAT and responds to all the M commands. The wiFi connects to the Network and the Com port is correct. However the DWC will not connect or open via the USB or the WiFi. I have tried every direction i can find including the Fall Back position 1 & 2 but still no joy.
      The problem seemed to occur during my first attempt. All went successfully updating software to current vers. 2.05 etc. DWC opened and connected via WiFi. I used the Configurator to update to Mini Kossel data, OK. Then Updated via Configurator a second time to correct some specific printer dimensions etc, Files uploaded and but DWC disconnected. That was 3 Days ago and now I have exhausted all avenues and need expert help please. What to do next? Iain S
      • A Former User
        A Former User last edited by
        Post the output of M122 to verify compatible wifi firmware. And M20 S2 P/www to verify DWC files in correct location.
        DWC is reliant on the files being in the /www folder on the SD card, but they should have been present on the supplied card, and you should also be offered to download them at the end of the configurator.
        • iains
          @bearer said in DWC connection denial:
          M20 S2 P/www
          Thank you for the response and follow up. Attached is a word file copy of the data you requested.
          I have included two SD cards. No 1 is the original card provided with the Duet. No, 2 is the downloaded SD i used to try and rectify the problem. Neither SD works?
          Regards Iain S
          SD Card No 2 & N0. 1 M122.docx
          • iains
            Hello Bearer
            Have you had a chance to look at my file as yet. My installation is currently dead in the water so was hoping for some early help. Hope you can get to it soon. Regards
            Iains
            • Danal
              Danal last edited by
              Not everyone has word. Please cut/paste directly into a post with three ``` before and after.
              This will
              show up like this
              This will
              show up like this
                For the sake of expediency:
                ![773343cc-8e33-470c-a99b-8294b54c3e0b-image.png](/assets/uploads/files/1588302235538-773343cc-8e33-470c-a99b-8294b54c3e0b-image.png)
                SD Card No 2 downloaded.
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                Board ID: 08DDM-9FAM2-LW4S4-6J1D8-3S86P-TMS7X
                Used output buffers: 1 of 24 (1 max)
                Static ram: 25712
                Dynamic ram: 92704 of which 0 recycled
                Exception stack ram used: 256
                Never used ram: 12400
                Tasks: NETWORK(ready,1876) HEAT(blocked,1232) MAIN(running,4752) IDLE(ready,160)
                Owned mutexes:
                Last reset 00:01:14 ago, cause: power up
                Last software reset time unknown, reason: Heat task stuck, spinning module GCodes, available RAM 11700 bytes (slot 1)
                Software reset code 0x00a3 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0443380f BFAR 0xe000ed38 SP 0x200049d4 Task 0x4e49414d
                Stack: 0042a2f1 0043b390 61000000 00000000 00000000 00000000 00000000 3331bb4c 41880000 3e178897 3e1cd04f be09b238 3e3a3fd4 00000000 00000000 00000000 3f800000 00000000 43820000 80000011 20007fd8 00000033 20007fd8
                Error status: 0
                Free file entries: 10
                MCU temperature: min 22.3, current 27.2, max 27.3
                Supply voltage: min 0.0, current 0.4, max 0.4, under voltage events: 0, over voltage events: 0, power good: no
                Driver 0: ok, SG min/max not available
                Driver 1: ok, SG min/max not available
                Driver 2: ok, SG min/max not available
                Driver 3: ok, SG min/max not available
                Driver 4: ok, SG min/max not available
                Cache data hit count 113378233
                Slowest loop: 0.15ms; fastest: 0.05ms
                Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                === DDARing ===
                Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                Segments left: 0
                Stack records: 0 allocated, 0 in use
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is idle in state(s) 0
                serial is ready with "M122" in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 0.15ms; fastest: 0.00ms
                HTTP sessions: 0 of 8
                - WiFi -
                Network state is disabled
                WiFi module is disabled
                Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
                Ok
                M20 S2 P/www
                Begin file list
                {"dir":"/www","first":0,"files":[],"err":2}
                End file list
                ALL FILES THAT ARE ON THE ORIGINAL DISC ARE PRESENT HERE ALSO EXCEPT FOR dw.Json?
                But M20 does not see them?
                SD Card N01. original supplied
                M20 S2 P/www
                Begin file list
                {"dir":"/www","first":0,"files":["favicon.ico.gz","html404.htm","language.xml.gz","reprap.htm.gz","*css","*fonts","*js","dwc.json"],"next":0,"err":0}
                End file list
                M122
                Used output buffers: 1 of 24 (11 max)
                Static ram: 25712
                Tasks: NETWORK(ready,1876) HEAT(blocked,1232) MAIN(running,3764) IDLE(ready,160)
                Owned mutexes:
                Last reset 00:47:25 ago, cause: power up
                Error status: 0
                MCU temperature: min 27.1, current 30.2, max 30.4
                Supply voltage: min 0.4, current 0.5, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
                Slowest loop: 299.37ms; fastest: 0.06ms
                === DDARing ===
                Segments left: 0
                === Network ===
                - WiFi -
                ok
                M552 S1
                ok
                WiFi module started
                WiFi module is connected to access point Sandcastle, IP address 10.0.1.5
                Browser response to; 10.0.1.5
                Your Duet rejected the HTTP request: page not found
                Check that the SD card is mounted and has the correct files in its /www folder
                Browser response to; http://duettest.local/
                This site can’t be reached  duettest.local’s server IP address could not be found.
                  I would suggest deleting the entire /www folder and recreating it, then in that folder, extract the contents of DWC 2.0.7 from the 2.05.1 firmware release.
                  • iains
                    Ok Thanks. I'm new to the Forum so still figuring it out also. Ill try your suggestion.
                      Phaedrux Moderator @iains last edited by
                      @iains said in DWC connection denial:
                      No worries. Usually copy and pasting into the post is the best way to share the info if possible. Opening up files on phones can be a challenge.
                      • iains
                        @Phaedrux said in DWC connection denial:
                        can you tell me the steps to extract the contents of DWC 2.0.7 from the 2.05.1 firmware release. please?
                          Sure. Download the zip file from here:
                          https://github.com/dc42/RepRapFirmware/releases/download/2.05.1/DuetWebControl-SD-2.0.7.zip
                          Then extract the contents into the /www folder.
                          Inside the /www folder you'd have these files if it's gone correctly.
                          └── www
                              ├── css
                              │   ├── Lumen.theme.css.gz
                              │   ├── Sandstone.theme.css.gz
                              │   ├── Slate.theme.css.gz
                              │   ├── Superhero.theme.css.gz
                              │   ├── United.theme.css.gz
                              │   ├── bootstrap.theme.css.gz
                              │   └── dwc.css.gz
                              ├── favicon.ico.gz
                              ├── fonts
                              │   ├── glyphicons.eot.gz
                              │   ├── glyphicons.svg.gz
                              │   ├── glyphicons.ttf.gz
                              │   ├── glyphicons.woff.gz
                              │   └── glyphicons.woff2.gz
                              ├── html404.htm
                              ├── js
                              │   └── dwc.js.gz
                              ├── language.xml.gz
                              └── reprap.htm.gz
