    SOLVED 3.01-RC9 Thermo Fan on Full
    Beta Firmware
    85
    • tekkydave
      tekkydave last edited by tekkydave
      Just upgraded from 3.01 RC6 to RC10 and notice my enclosure fans were on full belt.
      I tried RC7 to RC9 to see where this appears and it happens with RC9.
      I'm using the mcu-temp and drivers values to drive my enclosure fans on duex fan4 pins.
      Works OK on RC6,7,8 : I get a gradual increase in speed from 40% when mcu temp exceeds 26C
      On RC9,10 as soon as it goes over 26C (which it is on startup) the fans are on 100%
      Relevant config (full config.g attached below)
      M308 S2 Y"mcu-temp"
      M308 S3 Y"drivers"
      M950 F4 C"duex.fan4" Q500
      M106 P4 S1.0 H2:3 T26:65 L0.4 C"Enclosure Fans"
      Board: Duet 2 WiFi (2WiFi) plus Duex2
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.01-RC9 (2020-04-21b1)
      Duet WiFi Server Version: 1.23
      DWC 2.1.5 (I'm on this release as I already upgraded to RRF 3.01RC10 first)
      config.g
      Everything else seems to be ok although I haven't tried a print yet 🙂
      Edit: My hotend fan is working fine and comes on at 50C as specified.
      ~ tekkydave ~
      D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
      FreeCAD, PrusaSlicer
        What are the readings from sensors 2 and 3 at present? To find out either name them and then show them in DWC under Extras, or send M380 S2 and M308 S3.
        • tekkydave
          Cut & pasted from DWC console:
          27/04/2020, 14:40:30 M308 S2
          Sensor 2 type Microcontroller embedded temperature sensor, reading 27.6, last error: success
          27/04/2020, 14:41:06 M308 S3
          Sensor 3 type Stepper driver temperature warnings, reading 0.0, last error: success
          I'm in the middle of a print at the moment so can't make any config changes.
          ~ tekkydave ~
            Thanks, I confirm this as a bug. Will be fixed in next RC.
            • tekkydave
              OK, Thanks. I can live with a bit of fan noise for now 🙂
              ~ tekkydave ~
              • Garfield
                Garfield last edited by
                Now running RC10. This issue still present.
                gcode definition
                ; MCU
                M308 S2 Y"mcu-temp" A"CPU"
                M950 F2 C"!out4" A"MCU" Q25000 L.02
                M106 P2 T40:54 H2      ; set Duet cooling fan
                Fan comes on @ 100% at just over 40 and doesn't go back off until 39, no ramp whatsoever
                tekkydave 1 Reply Last reply Reply Quote 0
                • tekkydave
                  tekkydave @Garfield last edited by
                  @Garfield I think I mentioned the issue was present in RC9 & 10. I singled out RC9 as that was when it first appeared 🙂
                  ~ tekkydave ~
                  • Garfield
                    Must slow down and read - only saw the RC9 bit - tagged on because I saw your post and had issue, @DC42 indicated it was known and fixed in the next RC - but wasn't sure if he meant RC10 - I need to take a break from the printer this week I think .....
                    • jay_s_uk
                      jay_s_uk last edited by
                      Its part of this commit https://github.com/dc42/RepRapFirmware/commit/5dda6c9d5aaa24ea94f9246db73e702580e5d0dc which will beomcing in the next RC/Stable release
                      0 dc42 committed to dc42/RepRapFirmware
                      Bug fixes, and restore correct heigt after a tool change
                      Thermostatically-controlled fans were no longer forced to run at >=50%
                      PWM when on
                      Proportional control of thermostatic fans no longer worked
                      When restoring position after a pause or after skipping a build object,
                      the inverse bed compensation applied when recomputing the user position
                      did not take account of the tool offset
                      After a tool change, if on a FDM printer then we now move the new tool
                      to the correct Z height before resuming the print
                      Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32 port of RRF
                        dc42 administrators @Garfield last edited by
                        @Garfield said in 3.01-RC9 Thermo Fan on Full:
                        I meant RC11. You can find preview RRF binaries (not fully tested) at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
                        • Garfield
                          Not your fault here Dave - all mine .. speed read and responded too quickly ... just figuring that my backup process's are somewhat lacking after the RC10 crashes and re-applying updated configuration which is how I spotted this.
                          I'll try to do better.
                          • Schmart
                            Schmart last edited by
                            @dc42 I can confirm that the internal build / preview binary no longer spins my case fan at 100% 👍
                            Creality CR-20 Pro with a Duet 2 Maestro, 3Dfused X+Z-axis rail kit, HIWIN-based DIY solution for the Y-axis, E3D Hemera, working ST7565 MiniPanel and various other small hardware improvements.
                              Thanks for confirming this is fixed.
                              • tekkydave
                                Just upgraded to 3.01RC11 and the bug is fixed.
                                Many Thanks 🙂
                                ~ tekkydave ~
