    Filament Change working! But it extrudes a glob on restart?
    Filament Monitor
    • Demi
      Demi last edited by
      Hi everyone....its me again. The title captures the issue pretty well.
      From config.g:
      M591 D0 P1 C"io8.in" S1
      Working like a champ. It pauses, right on cue, life is good.
      But when it resumes the print (after I load fresh filament and purge a bit) it happily bounces back to its previous location, and dumps a bunch of filament and then continues.
      pause.g is pretty much untouched:
      M83            ; relative extruder moves
      G1 E-10 F3600  ; retract 10mm of filament
      G91            ; relative positioning
      G1 Z5 F360     ; lift Z by 5mm
      G90            ; absolute positioning
      G1 X0 Y0 F6000 ; go to X=0 Y=0
      Any ideas what sort of silly noob mistake Im making this time? Thanks everyone for all the help.
      DIY-O-Sphere 1 Reply Last reply Reply Quote 0
      • DIY-O-Sphere
        DIY-O-Sphere @Demi last edited by
        @Demi
        You have to check resume.g. There you will find the extrusion...
        (UTC+1)
        • Demi
          Demi last edited by
          Good lord. Thats pretty embarrassing. Of course its in resume. Thank you so much!
          JadonM 1 Reply Last reply Reply Quote 0
          • JadonM
            JadonM @Demi last edited by
            @Demi No problem! We all make such mistakes every once in a while! 😃
            I have it set so it simply retracts the proper amount after filament loading.
