    CHANGE OF DRIVE Y BY E0.
    • marinorafaundefined
      marinorafa
      UNFORTUNATELY I BURNED THE Y AXIS DRIVE BY CHANGING THE WIRES CAREFULLY.
      I'M TRYING TO USE DRIVE E0 AS A SUBSTITUTE OF Y, ONCE I ONLY HAVE AN EXTRUDER (E1), I HAVE A DIFFICULTY IN SETTING UP THE Y AXIS ENDSTOP, SOMEONE CAN HELP ME, SOMEONE DID IT. I AM ASSEMBLED BLV CUBE. THANK YOU. DUET WIFI
        dc42 administrators @marinorafa
        Leave the Y axis endstop switch connected to the Y endstop input. Changing the motor assignments (using M584) does not affect the endstop connector assignments.
        marinorafaundefined 1 Reply Last reply Reply Quote 1
          I think your caps lock key is broken.
          marinorafaundefined 1 Reply Last reply Reply Quote 0
            marinorafa @dc42
            @dc42 Thank you...
              marinorafa @Phaedrux
              @Phaedrux Sorry!
