    Mesh bed compensation warning
    45
    • bigsub
      bigsub last edited by
      hello everyone, I'm having a problem probing my bed with a smart ir on a duet2 wifi.
      Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
      I use this version:
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05.1 (2020-02-09b1)
      This is the portion of config.g with endstops and z-probe:
      M574 X1 Y1 S1 ;
      M574 Z1 S2 ;
      M558 P1 H5 F300 T4800 ;
      M557 X10:270 Y0:235 P07:07 ;
      G31 P500 X4 Y-0.5 Z2.45 ;
      In homez.g:
      G91 ;
      G1 H2 Z5 F4800 ;
      G90
      G1 X20 Y0 F4800 ; go to first probe point
      G30 ;
      Where could be the origin of this warning?
        Please post your full config and homeall. And Bed.g if you use that as well.
        https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#Section_Establish_a_Z_0_datum_using_the_Z_probe
        • bigsub
          homez.g homeall.g config.g bed.g
            @bigsub said in Mesh bed compensation warning:
            Have you redone your mesh lately?
            bigsub 1 Reply Last reply Reply Quote 0
            • bigsub
              bigsub @Phaedrux last edited by
              @Phaedrux said in Mesh bed compensation warning:
              Five minutes ago.
                Try moving your homing position to place the probe at the center of the bed.
                Are you using G32 (bed.g) to start the mesh probing?
                • bigsub
                  Ok for homing position.
                  I use G29.
                    Try using G32 to call it instead because your bed.g has M561 to clear the previous heightmap first.
