    Duet Pi Regression - How?
    Beta Firmware
    1.4k
    • Danalundefined
      Danal
      If a person chooses to regress DSF on a Pi, what is the most automated way? So far, I've come up with this:
      First - backup your files in /opt/dsf/sd/*, just in case.
      Then run:
      sudo apt remove duetsoftwareframework -y
      sudo apt autopurge -y
      sudo apt install duetsoftwareframework=1.2.3.0 -y
      Restore any files that went missing or overlay.
      AND, of course, if the board won't talk, bossa with the firmware found at /opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin". If it will talk, the 'apt' process should have loaded at least the main board when it installed the 'duetfirmware' package.
      Thoughts?
      • A Former User?
        A Former User @Danal
        Specifying a specific version for only DSF never has worked as apt seems to insist on installing the most recent version for all of DSF's dependencies which aren't compatible. Maybe aptitude can do a better job of it?
        also i think you need to remove duetruntime or that was a half finished thought. but seems autopurge might be excessive as it could remove configs from non duet packages; if purge is a goal i'd make sure to backup sd folder and specify apt purge duetcontrolserver duetruntime duetsd duetsoftwareframework duettools duetwebcontrol duetwebserver reprapfirmware (even though it may be subject to change if dsf gets new packages over time)
        pi@raspberrypi:~ $ sudo apt remove duetsoftwareframework -y
        Reading package lists... Done
        Building dependency tree
        Reading state information... Done
        Package 'duetsoftwareframework' is not installed, so not removed
        0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
        pi@raspberrypi:~ $ sudo apt autopurge -y
        pi@raspberrypi:~ $ sudo apt install duetsoftwareframework=1.2.3.0 -y
        Some packages could not be installed. This may mean that you have
        requested an impossible situation or if you are using the unstable
        distribution that some required packages have not yet been created
        or been moved out of Incoming.
        The following information may help to resolve the situation:
        The following packages have unmet dependencies:
         duetsoftwareframework : Depends: duetcontrolserver (= 1.2.3.0) but 2.1.1 is to be installed
                                 Depends: duetsd (= 1.0.5) but 1.0.6 is to be installed
                                 Depends: duettools (= 1.2.3.0) but 2.1.1 is to be installed
                                 Depends: duetwebserver (= 1.2.1.0) but 2.1.0 is to be installed
                                 Depends: duetwebcontrol (= 2.0.4-1) but 2.1.5 is to be installed
                                 Depends: reprapfirmware (<= 1.2.3.0-999) but 2.1.1-1 is to be installed
        E: Unable to correct problems, you have held broken packages.
        this post has a 95% shortcut to get an apt command to deal with the issue
        https://forum.duet3d.com/post/149932
        pi@raspberrypi:~ $ bash dsfdep.sh 1.2.3.0
        sudo apt install \
          duetcontrolserver=1.2.3.0 \
          duetruntime=1.2.3.0 \
          duetsd=1.0.5 \
          duettools=1.2.3.0 \
          duetwebserver=1.2.1.0 \
          duetwebcontrol=2.0.4-1 \
          reprapfirmware=1.2.3.0-1 \
        pi@raspberrypi:~ $ `bash dsfdep.sh 1.2.3.0` #note the backticks
        The following NEW packages will be installed:
        0 upgraded, 8 newly installed, 0 to remove and 0 not upgraded.
        Need to get 32.2 MB of archives.
        After this operation, 0 B of additional disk space will be used.
        Get:1 https://pkg.duet3d.com unstable/armv7 armhf duetruntime armhf 1.2.3.0 [28.7 MB]
        Get:2 https://pkg.duet3d.com unstable/armv7 armhf duetcontrolserver armhf 1.2.3.0 [173 kB]
        Get:3 https://pkg.duet3d.com unstable/armv7 armhf duetsd all 1.0.5 [1,998 B]
        Get:4 https://pkg.duet3d.com unstable/armv7 armhf duettools armhf 1.2.3.0 [49.9 kB]
        Get:5 https://pkg.duet3d.com unstable/armv7 armhf duetwebserver armhf 1.2.1.0 [70.7 kB]
        Get:6 https://pkg.duet3d.com unstable/armv7 armhf duetwebcontrol all 2.0.4-1 [2,811 kB]
        Get:7 https://pkg.duet3d.com unstable/armv7 armhf reprapfirmware all 1.2.3.0-1 [425 kB]
        Get:8 https://pkg.duet3d.com unstable/armv7 armhf duetsoftwareframework armhf 1.2.3.0 [1,710 B]
        Fetched 32.2 MB in 48s (671 kB/s)
        Selecting previously unselected package duetruntime.
        (Reading database ... 52338 files and directories currently installed.)
        Preparing to unpack .../0-duetruntime_1.2.3.0_armhf.deb ...
        Unpacking duetruntime (1.2.3.0) ...
        Selecting previously unselected package duetcontrolserver.
        Preparing to unpack .../1-duetcontrolserver_1.2.3.0_armhf.deb ...
        Unpacking duetcontrolserver (1.2.3.0) ...
        Selecting previously unselected package duetsd.
        Preparing to unpack .../2-duetsd_1.0.5_all.deb ...
        Unpacking duetsd (1.0.5) ...
        Selecting previously unselected package duettools.
        Preparing to unpack .../3-duettools_1.2.3.0_armhf.deb ...
        Unpacking duettools (1.2.3.0) ...
        Selecting previously unselected package duetwebserver.
        Preparing to unpack .../4-duetwebserver_1.2.1.0_armhf.deb ...
        Unpacking duetwebserver (1.2.1.0) ...
        Selecting previously unselected package duetwebcontrol.
        Preparing to unpack .../5-duetwebcontrol_2.0.4-1_all.deb ...
        Unpacking duetwebcontrol (2.0.4-1) ...
        Selecting previously unselected package reprapfirmware.
        Preparing to unpack .../6-reprapfirmware_1.2.3.0-1_all.deb ...
        Unpacking reprapfirmware (1.2.3.0-1) ...
        Selecting previously unselected package duetsoftwareframework.
        Preparing to unpack .../7-duetsoftwareframework_1.2.3.0_armhf.deb ...
        Unpacking duetsoftwareframework (1.2.3.0) ...
        Setting up duetruntime (1.2.3.0) ...
        Setting up duetwebcontrol (2.0.4-1) ...
        Setting up duetcontrolserver (1.2.3.0) ...
        Setting up duettools (1.2.3.0) ...
        Setting up duetwebserver (1.2.1.0) ...
        Setting up duetsd (1.0.5) ...
        Setting up reprapfirmware (1.2.3.0-1) ...
        [error] Duet is not available
        Setting up duetsoftwareframework (1.2.3.0) ...
        pi@raspberrypi:~ $
        • Danalundefined
          Danal
          To the autopurge point, yah, I'd like to avoid that for exactly those two reasons: removes 'non package' files and could remove anything that apt thinks it should, outside the duet universe.
          At the same time, I thought it would create a state where apt install with version number didn't do the "broken" thing. Obviously, it does not.
          So... part of the reason for asking this question was to see if regression is worth scripting. Something that spits out all the commands, much like depcheck. Probably is...
          • Danalundefined
            Danal
            Why is that 95%? Or what is the 5% edge case?
            • A Former User?
              @Danal said in Duet Pi Regression - How?:
              afaik the only flaw is the recursive checking i limited to duetframework because it was the only package without a direct dependency to dsf (i.e. if that changes it fails, but then apt will complain so safe-ish)
              Danalundefined 1 Reply Last reply Reply Quote 0
              • Danalundefined
                Danal @A Former User
                @bearer said in Duet Pi Regression - How?:
                Thanks!
                • A Former User?
                  A Former User
                  and purging duetsd will clear out the most of /opt/dsf/sd folder configs, macros, gcode, everything.
                  • A Former User?
                    oh, and there is something weird with the reprapfirmeware n.n.n.n-1 and n.n.n.n-999 dependenices for otherwise identical versions. so i ignore the 999 in the rexeg
                    • Danalundefined
                      and purging duetsd will clear out the whole /opt/dsf/sd folder configs, macros, gcode, everything.
                      Agreed. I'm now on the warpath to avoid 'apt purge'.
                      'apt remove' only removes things in the package manifest, and deletes empty directories. If non empty, it will leave them. I believe the one time I regressed (by a manual method) that everything stayed intact, EXCEPT config.g had been overlaid with the empty-ish distribution copy. All other files, like tfree and tpost and so forth, and macros, they were all intact.
                      • Danalundefined
                        Me too.
                        • Danalundefined
                          Danal
                          With regard to "how to recurse" without depending on the exact structure of the package, this seems to work, then parse the "depends" line:
                          apt show duetsoftwareframework=1.2.3.0
                          Package: duetsoftwareframework
                          Version: 1.2.3.0
                          Priority: standard
                          Section: electronics
                          Maintainer: Duet3D Packaging Authority <pkg@duet3d.com>
                          Installed-Size: unknown
                          Depends: duetcontrolserver (= 1.2.3.0), duetsd (= 1.0.5), duettools (= 1.2.3.0), duetwebserver (= 1.2.1.0), duetwebcontrol (= 2.0.4-1), reprapfirmware (>= 1.2.3.0-1), reprapfirmware (<= 1.2.3.0-999)
                          Homepage: https://pkg.duet3d.com
                          Vcs-Git: https://github.com/chrishamm/DuetSoftwareFramework.git
                          Download-Size: 1,710 B
                          APT-Manual-Installed: yes
                          APT-Sources: https://pkg.duet3d.com unstable/armv7 armhf Packages
                          Description: Meta package for the full Duet software framework
                          • A Former User?
                            this seems to work,
                            missing duetruntime which is why i turne to recusion that ultimately failed if left run to to all the leaf nodes.
                            • Danalundefined
                              Danal
                              Hmmm... I wonder how it gets installed? With no dependency?
                              • A Former User?
                                duetcontrolserver has it as a dependency iirc (thus the recursion)
                                • Danalundefined
                                  Danal
                                  Ah, light bulb just came on. Thank you.
                                  • Danalundefined
                                    Danal
                                    And, by the way, autopurge (which I am NOT going to use) actually does not purge the recursive stuff after a
                                    sudo apt install duetsoftwareframework=1.2.3.0 duetcontrolserver=1.2.3.0 duetruntime=1.2.3.0 duetsd=1.0.5 duettools=1.2.3.0 duetwebserver=1.2.1.0 duetwebcontrol=2.0.4-1 reprapfirmware=1.2.3.0-1
                                    style install, and an apt remove duetsoftwareframework.
                                    So.... it would not have worked anyway.
                                    • gtj0undefined
                                      gtj0
                                      Just switch to RPM 😂
                                      A Former User? Danalundefined 2 Replies Last reply Reply Quote 1
                                      • A Former User?
                                        A Former User @gtj0
                                        @gtj0 said in Duet Pi Regression - How?:
                                        +2
                                        was wondering if aptitude* would be better suited, but decided to brush up on regex instead 😇
                                        *) not better than RPM..
                                        • Danalundefined
                                          Danal @gtj0
                                          How about //STEP1 EXEC PGM=SMPE? It handled prereqs, coreqs, and even postreqs flawlessly. Why, I've heard you could build and entire OS with it!
                                          • A Former User?
                                            apt remove duet* reprapfirmware is about the same length and oddly more specific. would work with remove and purge for that matter.
