    Duet Pi Regression - How?
    Beta Firmware
    1.4k
      A Former User @Danal
      @Danal said in Duet Pi Regression - How?:
      Why is that 95%? Or what is the 5% edge case?
      oh, and there is something weird with the reprapfirmeware n.n.n.n-1 and n.n.n.n-999 dependenices for otherwise identical versions. so i ignore the 999 in the rexeg
      • Danalundefined
        Danal @A Former User
        @bearer said in Duet Pi Regression - How?:
        and purging duetsd will clear out the whole /opt/dsf/sd folder configs, macros, gcode, everything.
        Agreed. I'm now on the warpath to avoid 'apt purge'.
        'apt remove' only removes things in the package manifest, and deletes empty directories. If non empty, it will leave them. I believe the one time I regressed (by a manual method) that everything stayed intact, EXCEPT config.g had been overlaid with the empty-ish distribution copy. All other files, like tfree and tpost and so forth, and macros, they were all intact.
        • Danalundefined
          Me too.
          • Danalundefined
            Danal
            With regard to "how to recurse" without depending on the exact structure of the package, this seems to work, then parse the "depends" line:
            apt show duetsoftwareframework=1.2.3.0
            Package: duetsoftwareframework
            Version: 1.2.3.0
            Priority: standard
            Section: electronics
            Maintainer: Duet3D Packaging Authority <pkg@duet3d.com>
            Installed-Size: unknown
            Depends: duetcontrolserver (= 1.2.3.0), duetsd (= 1.0.5), duettools (= 1.2.3.0), duetwebserver (= 1.2.1.0), duetwebcontrol (= 2.0.4-1), reprapfirmware (>= 1.2.3.0-1), reprapfirmware (<= 1.2.3.0-999)
            Homepage: https://pkg.duet3d.com
            Vcs-Git: https://github.com/chrishamm/DuetSoftwareFramework.git
            Download-Size: 1,710 B
            APT-Manual-Installed: yes
            APT-Sources: https://pkg.duet3d.com unstable/armv7 armhf Packages
            Description: Meta package for the full Duet software framework
              this seems to work,
              missing duetruntime which is why i turne to recusion that ultimately failed if left run to to all the leaf nodes.
              • Danalundefined
                Danal
                Hmmm... I wonder how it gets installed? With no dependency?
                  duetcontrolserver has it as a dependency iirc (thus the recursion)
                  • Danalundefined
                    Danal
                    Ah, light bulb just came on. Thank you.
                    • Danalundefined
                      Danal
                      And, by the way, autopurge (which I am NOT going to use) actually does not purge the recursive stuff after a
                      sudo apt install duetsoftwareframework=1.2.3.0 duetcontrolserver=1.2.3.0 duetruntime=1.2.3.0 duetsd=1.0.5 duettools=1.2.3.0 duetwebserver=1.2.1.0 duetwebcontrol=2.0.4-1 reprapfirmware=1.2.3.0-1
                      style install, and an apt remove duetsoftwareframework.
                      So.... it would not have worked anyway.
                      • gtj0undefined
                        gtj0
                        Just switch to RPM 😂
                        A Former User? Danalundefined 2 Replies Last reply Reply Quote 1
                          A Former User @gtj0
                          @gtj0 said in Duet Pi Regression - How?:
                          +2
                          was wondering if aptitude* would be better suited, but decided to brush up on regex instead 😇
                          *) not better than RPM..
                          • Danalundefined
                            Danal @gtj0
                            How about //STEP1 EXEC PGM=SMPE? It handled prereqs, coreqs, and even postreqs flawlessly. Why, I've heard you could build and entire OS with it!
                              apt remove duet* reprapfirmware is about the same length and oddly more specific. would work with remove and purge for that matter.
                              • Danalundefined
                                Yah, I thought about the nicely structured names. As you said though, if the package changes...
                                  then it has a greater chance of catching it as duetruntime still doesn't depend on duetsoftwareframework.
                                  and if apt remove duetcontrolserver duetruntime duetsd duetsoftwareframework duettools duetwebcontrol duetwebserver reprapfirmware is the alternative then it needs to be updated anyways.
                                  to be honest I have more faith in a * than apt and dependencies defined for the packages should autoremove fail.
                                  • Danalundefined
                                    Danal
                                    OK, here is a "first draft" that works. Comments welcome:
                                    ./DuetRegress.sh 2.1.0
                                    Currently Installed duetsoftwareframework=
                                    Command line argument is requesting duetsoftwareframework=2.1.0
                                    Which has associated reprapfirmware of 2.1.0-1 also known as 3.01-RC9
                                    * Note: The next step will run for a while; the script is (probably) not hung.    *
                                    To regress to DSF version 2.1.0 which is RRF version 3.01-RC9:
                                    1) Backup your files via:
                                      mkdir ~/duetback
                                      cp -r /opt/dsf/sd/* ~/duetback
                                    or similar. Verify that the backup worked: 'ls ~/duetback' should show directories: 'filaments firmware gcodes macros sys' or similar.
                                    2) Run this command: (it is long, be sure you get it all on one line)
                                      sudo apt -y  --allow-downgrades install duetsoftwareframework=2.1.0 duetcontrolserver=2.1.0 duetruntime=2.1.0 duetsd=1.0.6 duettools=2.1.0 duetwebcontrol=2.1.4 duetwebserver=2.1.0 reprapfirmware=2.1.0-1
                                    3) Verify system is running properly, web interface opens, etc
                                    4) If Pi runs, but won't connect to Duet Board, bossa the board
                                       with the file found at /opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin
                                       Instructions here:
                                       https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware
                                    5) Check files like config.g, macros, etc, and restore as required.
                                    There are no name or other recursion dependencies in the script. Also, I took out the "apt remove" command, I don't believe it is required, apt will just overlay things.
                                      A Former User
                                      i opted for splitting the lines so it can be easy to read and copy, or if piped/backticked its not.
                                      i'd also reconsider the -y bit gives apt a chance to complain if it feels the need.
                                      pi@raspberrypi:~ $ bash rrfdep.sh 3.01-RC9
                                      sudo apt install \
                                        duetcontrolserver=2.1.0 \
                                        duetsd=1.0.6 \
                                        duettools=2.1.0 \
                                        duetwebserver=2.1.0 \
                                        duetwebcontrol=2.1.4 \
                                        reprapfirmware=2.1.0-1 \
                                      pi@raspberrypi:~ $
                                      don't think i'll put up the version that resolves it from the reprap firmware version, smells like lots of unnecessary load on servers just to save people looking up a table
                                      • Danalundefined
                                        Danal
                                        Excellent idea on the lines! I will do that. In fact, I was a bit concerned about line length... not only that, but I'm flattening a 'list' now, all I have to do is not do that.
                                        I go back and forth on the -y. Given that this is intended to be used by people who literally can't even answer the initial "Do you want me to do what you asked? [Y/n]" prompt... well... I'm inclined to leave it in.
                                        re: servers, yeah, this one is entirely local. In fact, it ought to insist on a recent (whatever that means) sudo apt update.
                                        Danalundefined A Former User? 2 Replies Last reply Reply Quote 0
                                        • Danalundefined
                                          Danal @Danal
                                          This post is deleted!
                                            you don't get any questions if you have all the packages specified; the one you're missing is (likely) libunwind8 (if there are questions) no idea how that snuck into anything, but the rest holds true..
                                            ref the bottom code block; no -Y and no question (also before libunwind8) https://forum.duet3d.com/post/150402
