    Couple Stepper Drivers
    • Fickert
      Fickert last edited by Fickert
      Is it possible to join together two stepper drivers to output onto a single motor for the purpose of increasing stepper driver total current? Can you just join the stepper drivers together and only hook up each opposing coil from either stepper driver?
        No, that's not a safe thing to do. The choppers in the stepper drivers run from their own internal clocks, so they won't be in sync.
        Fickert 1 Reply Last reply Reply Quote 0
        • A Former User
          A Former User last edited by
          Probably better off hooking up an external stepper driver if you're not using the expansion for whichever board you're using?
          How much current do you need?
          • Fickert
            Fickert @dc42 last edited by
            @dc42 said in Couple Stepper Drivers:
            Dang I will be running Nema23's rated at 4A. Two on the Y-axis and one on the X-axis. I think driving the two Y axis motors each wither their own stepper will be enough but not sure on the X-axis. This is for a 4x6ft CNC table.
            I guess I will just have to see. Worst case if it does not work out I can add external drivers.
            • Fickert
              Fickert @Guest last edited by Fickert
              @bearer said in Couple Stepper Drivers:
              I am using the Duet Wifi. I think @ 2.4A from the Duet (if that is sustainable for everyday use, will definitely have strong active cooling) on the 4A motors should be good for slower speeds. I am pairing them with a T12x2 leadscrews so there should be ample torque, just curious about speeds with that small of a pitch.
                Preferably, either choose Nema 23 motors with a lower rated current (e.g. 2.8A), or use Duet 3 to drive the 4A ones.
                You can estimate the maximum speed using the EMF calculator at repeapfirmware.org.
