    SOLVED Duet 3 Slow Hotend Heatup, can't even run PID tuning
    • fractalengineer
      fractalengineer last edited by
      I'm using a 24V 50W cartridge with a Dyze high temp thermistor on a mosquito hotend.
      The R value is appropriate (2200) and the displayed temperature is accurate (measured with a meat thermometer lol)
      However the heatup cycle is painfully slow, and can't even complete the PID tuning cycle in time.
      I tried with different P values; 0.35, 0.5, 1
      Here's the relevant part of my config.g:
      ; Thermistors
      M308 S0 P"temp0" Y"thermistor" A"bed_heat" T100000 B4240 H0 L0 		;Bed thermistor - connected to temp0
      M308 S1 P"temp1" Y"thermistor" A"e0_heat" T4606017 B5848 C5.548428e-8 R2200 H0 L0	;Dyze 500c thermistor - connected to e0_heat
      ; Define Heaters
      M950 H0 C"out0" T0				;Bed heater is on out0
      M950 H1 C"out1" T1				;Hotend heater is on out1
      ; Heater model parameters
      M307 H0 A90.0 C700.0 D10.0 S1.00 B1 		;Keenovo duet 3 configuration
      M307 H1 A580.4 C256.6 D6.4 S0.50		  ; Heating process parameters for 24V a system
      M570 S360					;Hot end may be a little slow to heat up so allow it 180 seconds
      M143 S300					;Set max hotend temperature
      Any thoughts?
      Cheers!
      Railcore II ZL
      A Former User 1 Reply Last reply Reply Quote 0
      • A Former User
        A Former User @fractalengineer last edited by
        @fractalengineer said in Duet 3 Slow Hotend Heatup, can't even run PID tuning:
        Is it? Not sure, and mobile, but if you leave R out, the firmware will use the correct value for your board so that's a sure way of doing it.
        • aidar
          aidar last edited by
          In your config, heater H1 (witch is hotend i assume) is defined to use only 0.5 (S parameter in M307 command) PWM signal. Make it 1.0 (or remove S parameter at all) and try again.
          fractalengineer 1 Reply Last reply Reply Quote 0
          • fractalengineer
            fractalengineer @aidar last edited by
            @bearer , @aidar
            Well that's uncanny;
            I thought R2200, P1.0 were the Duet3 standard values so I left them on
            Removing them actually solved the issues; PID tuning is complete and it heats up to temp in seconds
            That board is smarter than it looks 😂
            Thanks!
            Railcore II ZL
            A Former User 1 Reply Last reply Reply Quote 1
            • A Former User
