Tool board to Duet 3 wiring
I am trying to wire up my tool board to my Duet 3. Per the documentation of the DUET 3 and tool board I have connected the following Pins via twisted pair cat5
Tool CAN pin 1 w/orange - Duet Can Pin 4
Tool CAN pin 2 orange - Duet Can Pin 1
Tool CAN pin 3 w/blue - Duet Can Pin 3
Tool CAN pin 4 blue - Duet Can Pin 2No luck connecting however with M115 B121 or b10 . I get the following messages:
4/29/2020, 8:56:27 PM Connection to Duet established
4/29/2020, 8:56:26 PM Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)Previously I also tried a straight through connection pin 1 to pin 1, pin 2 to pin 2 etc...
Does someone know what I am missing here?
Duet 6HC connector, RJ11:
Toolboard connector, JST ZH:
With CAN, H connects to H, and L to L. The 6HC uses CAN1, the center pins, as primary. (CAN0 may have future uses). Therefore, the cable that connects a 6HC and a Toolboard must connect:
- 6HC pin 3 to Toolboard Pin 4
- 6HC Pin 4 to Toolboard Pin 3
If you add tool boards, to chain them:
- toolboard0 pin 2 to toolboard1 pin 4
- toolboard0 pin 1 to toolboard1 pin 3
And finally (ha ha), to terminate the CAN bus:
- The 'last' toolboard in the chain must have a 120Ohm resistor across pins 1 and 2. It will probably seem to run without this, but not having it can cause very obscure problems down the road.
All above is what a 'tool distribution board' does, with jumpers to let you select which connectors are bypassed and who terminates (or not).
P.S. Those schematics are on Github.
@jdumoulin said in Tool board to Duet 3 wiring:
Tool CAN pin 4 blue - Duet Can Pin 2try
43
Tool CAN pin 3 w/blue - Duet Can Pin34and a 120R termination resistor accross tool CAN pin 1 and 2.
edit: whops, I guess thats why i normally link to the answer instead of reproducing it..
https://forum.duet3d.com/post/133825
@bearer said in Tool board to Duet 3 wiring:
try
Tool CAN pin 4 blue - Duet Can Pin 4
Tool CAN pin 3 w/blue - Duet Can Pin 3Copy of above with H and L added:
Tool CAN pin 4 (CAN_H) blue - Duet Can Pin 4 (CAN_L)
Tool CAN pin 3 (CAN_L) w/blue - Duet Can Pin 3 (CAN_H)@bearer that seems to reverse H/L. Did I miss something?
Hey guys,
Thank you for your help. I really did search all over the forum but didn't realize to check GitHub.
Thanks again. I will give this a try next week when I am near my printer again.
Hey guys,
I followed danal’s directions, as I asked your question a week or so ago too - works perfectly. The key was the terminating resistor.
@Nuramori said in Tool board to Duet 3 wiring:
Thank you. It is working now
