    12v RGB Leds - Using GPIO on Duex
    My Duet controlled machine
    1
    1
    115
    • PaulHewundefined
      PaulHew
      I was following this link on RGB lights.
      DC42 mentions that the GPIO ports can be used.
      My RGB LEDs have a common positive and then neutrals for the colours.
      I have changed the V_Fan select jumper to 12V and tested using a fan output, all works.
      My question is
      Can I connect the negative wires for the individual colours to the GPIO pins OR do I need something between the pin and the LED strip, and will I be able to dim each of the channels on the GPIO outputs?
      Thanks in Advance,
      Regards,
      Paul.
      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
