    Duet Driver Issues
    Firmware installation
    • IGENundefined
      IGEN
      I'm having issues connecting my Duet 2 Maestro to my computer.
      This is what it looks like in the device manager:
      When I check the installed drivers in the properties section I see this:
      I can target the file where I have downloaded the ".cat" and ".inf" files, but apparently no drivers are better than the right drivers.
      If I manually target the drivers through the "have disk" route:
      Any help would be much appreciated!
        Try removing that device, unplugging the board, rebooting, and then try a different port.
        • A Former User?
          A Former User
          It won't find a matching driver with the "Device descriptor request failed" error, which is a hardware issue most likely. Bad cable, bad port or bad board.
          Try what @Phaedrux suggested and see if you can clear that error then proceed with installing the driver.
            If you have a USB hub that may also help.
            • IGENundefined
              IGEN
              It seems to be a bad port. I tried on my surface laptop and then my pc. After trying a second port on the PC it worked! Thanks for all the help!
