    Mesh grid (557) restored to old value after homing Z
    • ernstcundefined
      ernstc
      My configuration is Duet3 + Raspberry + RRF 3.0 (2020-01-03b3).
      In the beginning my mesh grid settings were:
      M557 X38:268 Y61:254 S40.0:40.0
      I changed the mesh grid in config.g as below:
      M557 X38:268 Y61:254 S80.0:80.0
      The problem is that when I home Z, the mesh grid is restored to the old values with spacing 40.0 instead of 80.0. I can't find any *.g file with an M557 command.
      Where are stored configuration files in the SD of the Rasperry? Can't find them either navigating in the file system.
      Thanks.
      gtj0undefined dc42undefined 2 Replies Last reply Reply Quote 0
      • gtj0undefined
        gtj0 @ernstc
        @ernstc They're in /opt/dsf/sd.
        You may want to consider upgrading to the latest versions. There have been LOTS of changes/fixes since the version you're running.
          dc42 administrators @ernstc
          @ernstc said in Mesh grid (557) restored to old value after homing Z:
          Do you have a G29 S1 command in homez.g to load an existing height map? If so, that will reset the grid to match the one in the height map.
          ernstcundefined 1 Reply Last reply Reply Quote 1
          • ernstcundefined
            ernstc @dc42
            @dc42 Yes, I have. Thanks!
            So, the solution is to change the grid and then execute the mesh bed probing, so that the height map file is updated.
