    Monitor bed heating?
    208
    • Elkoundefined
      Elko
      Hi
      there is a possibility to monitor the bed heating ?
      I only want to run the fan for the Mosfet of the bed heater when the bed heater is switched on
      • botundefined
        bot
        Set up a thermostatic fan linked to the bed heater at a specific temperature.
        see: https://duet3d.dozuki.com/Wiki/Gcode#Section_M106_Fan_On
        *not actually a robot
        • Elkoundefined
          Elko
          Hello bot
          I know that.
          But I would like a query whether the heating is ON or OFF
          • Elkoundefined
            Elko
            void controllerfan_update() {
            static millis_t lastMotorOn = 0, // Last time a motor was turned on
            nextMotorCheck = 0; // Last time the state was checked
            const millis_t ms = millis();
            if (ELAPSED(ms, nextMotorCheck)) {
            nextMotorCheck = ms + 2500UL; // Not a time critical function, so only check every 2.5s
            const bool xory = X_ENABLE_READ() == X_ENABLE_ON || Y_ENABLE_READ() == Y_ENABLE_ON;
            // If any of the drivers or the bed are enabled...
            if (xory || Z_ENABLE_READ() == Z_ENABLE_ON
              #if HAS_HEATED_BED
                || thermalManager.temp_bed.soft_pwm_amount > 0
              #endif
                #if HAS_X2_ENABLE
                  || X2_ENABLE_READ() == X_ENABLE_ON
                #endif
                #if HAS_Y2_ENABLE
                  || Y2_ENABLE_READ() == Y_ENABLE_ON
                #endif
                #if HAS_Z2_ENABLE
                  || Z2_ENABLE_READ() == Z_ENABLE_ON
                #endif
                #if HAS_Z3_ENABLE
                  || Z3_ENABLE_READ() == Z_ENABLE_ON
                #endif
                #if E_STEPPERS
                  #define _OR_ENABLED_E(N) || E##N##_ENABLE_READ() == E_ENABLE_ON
                  REPEAT(E_STEPPERS, _OR_ENABLED_E)
                #endif
              lastMotorOn = ms; //... set time to NOW so the fan will turn on
            // Fan off if no steppers have been enabled for CONTROLLERFAN_SECS seconds
            controllerfan_speed = (!lastMotorOn || ELAPSED(ms, lastMotorOn + (CONTROLLERFAN_SECS) * 1000UL)) ? 0 : (
              #ifdef CONTROLLERFAN_SPEED_Z_ONLY
                xory ? CONTROLLERFAN_SPEED : CONTROLLERFAN_SPEED_Z_ONLY
              #else
                CONTROLLERFAN_SPEED
              #endif
            • Elkoundefined
              Elko
              Just like in Marlin
                Using RRF3 you could do that in the daemon.g file.
                whosrdaddyundefined 1 Reply Last reply Reply Quote 0
                • whosrdaddyundefined
                  whosrdaddy
                  Maybe I don't understand the question well,
                  but when the SSR is enabled (ie the bed is heating) you can simply setup a thermostatic trigger to enable the fan like
                  M106 P1 T40 H0 (change P1 to your actual fan output)
                    whosrdaddy @dc42
                    @dc42 : I don't find any docs for daemon.g except for this tweet of yours 😉
