    ESP8266 Color Touchscreen Print Monitor
    235
    • bitsplusatoms
      bitsplusatoms last edited by
      I've been working on a little print monitor using an ESP8266 and a 2.4" color touchscreen display to monitor up to four printers (see pictures). Three of my printers are Marlin with OctoPrint, and my newest is a Duet-based machine. This is solely a monitor - it does not perform any control. I'll be posting the whole thing to github when it is slightly less of a shambles.
      I'm just beginning to add Duet support and I have a couple of questions on the use of rr_connect / rr_disconnect.
      First, do I need to use them at all? I can run curl commands against my printer without first performing an rr_connect.
      If I should use them, should I perform an rr_connect followed by rr_status / rr_fileinfo and then an rr_disconnect every time I want to poll status? If not, when should they be used?
      Input is appreciated.
      Joe
      IMG_2400.jpeg IMG_2402.jpeg IMG_2403.jpeg IMG_2404.jpeg IMG_2405.jpegIMG_2406.jpeg
      A Former User dc42 2 Replies Last reply Reply Quote 3
      • A Former User
        A Former User @bitsplusatoms last edited by
        @bitsplusatoms said in ESP8266 Color Touchscreen Print Monitor:
        if you search for rr_disconnect you'll get some background while waiting for the details, all i remember of the top of my head is its been recommended
        zapta 1 Reply Last reply Reply Quote 0
        • zapta
          zapta @Guest last edited by zapta
          @danal has working code. May be useful for you as an example. Notice the different handling of Duet2 and Duet3.
          https://github.com/DanalEstes
          Danal 1 Reply Last reply Reply Quote 0
          • tobias_munich
            tobias_munich last edited by
            this is going in a similar direction
            https://forum.duet3d.com/topic/14134/duet-buddy-a-proof-of-concept-remote-monitor
            Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
            Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
            Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
            bitsplusatoms 1 Reply Last reply Reply Quote 0
            • Danal
              Danal @zapta last edited by Danal
              @zapta said in ESP8266 Color Touchscreen Print Monitor:
              Yeah, I decided to "abstract" the 2 to 3 differences for other scripts. This has worked out pretty well. See https://github.com/DanalEstes/DuetWebAPI/blob/master/DuetWebAPI.py for the abstraction. Even if you don't know any python, it is straightforward to read if you just assume it does what it seems (like json.loads is probably a json parser. It is).
                dc42 administrators @bitsplusatoms last edited by dc42
                If you are polling or sending commands frequently, use rr_connect at the start and after a network error, and do not use rr_disconnect. If you are polling less than once every few seconds, use rr_connect and rr_disconnect around each poll.
                bitsplusatoms 2 Replies Last reply Reply Quote 0
                • bitsplusatoms
                  bitsplusatoms @dc42 last edited by
                  @dc42 Thank you. That’s exactly what I needed to know. I will be polling every 10 seconds during a print and once a minute while idle (to determine whether a new print has started).
                  • bitsplusatoms
                    bitsplusatoms @tobias_munich last edited by
                    @tobias_munich Thank you for the pointer. I found this project previously but wasn’t able to answer my question based on it. I should have mentioned that.
                    • bitsplusatoms
                      bitsplusatoms @Danal last edited by
                      @Danal This is great. Your code will be a nice reference for me. Thank you.
                      • bitsplusatoms
                        @dc42 One more question... I've been looking at the DWC code so I think I know the answer, but I want to be sure.
                        It does not appear that there is a way to determine solely through a single invocation of rr_status or rr_fileinfo that a print has completed. That is, after a print has completed, rr_fileinfo will return { "err" : 1 } and rr_status will report { "status" : "I"} and no indication that a prior print has completed.
                        It appears that the client code must notice that a transition has occurred from a printing state to an idle state and make a presumption about completion.
                        In other words, there is no concept of a "Completed" state other than in the eye of the client.
                        TIA,
                        Joe
                        • bitsplusatoms
                          More to do, but progress. In the first image (the overview screen) the machine labeled UXL is a Duet3D based machine. The others are Marlin/OctoPrint.
                            Correct. You can also use the 'job' field of the object model to track print progress.
                            • bitsplusatoms
                              @dc42 Thank you. I've spent a little time on it this weekend and think I have a reasonable approach in place for state transitions and time estimates using the "timesLeft" data.
                              • bitsplusatoms
                                It's getting there. All the code is on github but it is labeled as a work-in-progress. The models for the enclosure (2 variants) should be on thingiverse this weekend.
                                I have asked a friend to try to follow the documentation and build one of these from scratch. Once he has either reported success or alerted me to problems in the documentation, code, dependencies, or whatever else, I'll fix/update it.
