    Macro within a macro
    My Duet controlled machine
    • PaulHewundefined
      PaulHew
      I have looked in the Wiki's and anywhere else I can think of to find an answer to my question, but no success!
      I am running the latest RRF3 on a Duet2 Ethernet with Duex5
      If I am running a macro and call another macro from it, what happens to the original macro, does it continue or wait for the called macro to finish before continuing?
      For instance.
      Macro1 - does a bed leveling procedure.
      Macro2 - fades the RGB lights up and down in red. (Lots of copy and paste!)
      ;Level bed Macro
      M98 "Macro2.g" ; start fade the lights to indicate something is happening.
      do ; carry on with my leveling procedure
      my
      leveling
      commands
      here
      etc
      ;Stop Macro2.g somehow!!
      If it does just 'call' Macro2 and continue, can I stop Macro2 when Macro1 is finished?
      Regards,
      Paul
      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
        The original macro will be paused until the one it called has completed.
        PaulHewundefined 1 Reply Last reply Reply Quote 0
        • PaulHewundefined
          PaulHew @dc42
          @dc42 That was quick David, thank you.
          Will the Duet2 ever be able to run a 'called / sub' process independantly?
          Out of interest, can the Duet3?
          So the best I can do is turn the red LEDs on full, and off at the end. 😞
          Thanks again.
          Paul
            dc42 administrators @PaulHew
            @PaulHew said in Macro within a macro:
            The only independent subprocess on Duet 2 or Duet 3 in standalone mode is the daemon.g file. You could use that to control your LEDs. On Duet 3 with attached SBC, many things are possible using plugins.
