Fan connections..
I’m just a beginner trying to modify and update my Delta printer. I’m installing a Duet Wi-Fi board and know this is a very elementary question for most hobbyists.
In wiring the Duet board I would like to know what is normally a Fan 0, Fan1, Fan2 and what fans are normally always on?
Thanks….
Have you seen this?
https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans
Typically Fan 0 is the part cooling fan because that's what most slicers expect. And Fan 1 is the hotend fan, and the duet will turn that on immediately at power on in acse there was a reset while the hotend was hot.
Thanks Much for the link...
