Z2 end stop won't appear in web interface
Hi I am new here, thanks for allowing me access.
I have 2 Duet Maestro (genuine) that I have just purchased and I am using them on cartesian printers with dual independent Z motors and end stops.
Can I have the Z2 end stop appear in the web interface so that I can test it.Thanks Heaps
Greg.
@gomond Please post your config.g and firmware version.
Have you wired the 2 independent Z's by removing the jumpers or have you used one Z on the Z and the second Z on E1?
Hi Paul
Yes I have 1 on Z and the other on E1 and the same with the micro switches.
I will post the config tomorrow.Thanks Greg.
Assuming you're trying to do leveling with the endstops, check this out: https://duet3d.dozuki.com/Guide/Independent+Z+motors+and+endstop+switches+in+RRF2/18
@Phaedrux
Thanks
Yes I have read through the forum and understand the mechanics of it all just not how to get the E1 end stop to appear in the web interface so that I can visually check the polarity and status of my Z2 end stop switch.Thanks again.
Greg
What do you see if you send m119?
07/05/2020, 17:21:03 M119
Endstops - X: not stopped, Y: at min stop, Z: not stopped, Z probe: not stopped
: Configuration file for Duet Maestro (firmware version 3)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Mar 14 2020 21:23:16 GMT+1100 (AEDT); General preferences
M550 P"Stevo Special" ; set printer name
M918 P1 E4 F2000000 ; configure direct-connect display; Network
M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet; Stepper Drives
M569 P4 S0 ; physical drive 3 goes Backwards;M584 X0 Y1 Z2 E3 ; set default drive mapping
M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z400.00 E140.00 ; set steps per mm @ 16 Microsteps
M566 X900.00 Y900.00 Z900.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z2000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z200.00 E250.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X210 Y210 Z150 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure active-low endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure active-low endstop for low end on Y via pin ystop
M574 Z1 S1 P"zstop" ; configure active-low endstop for low end on Z via pin zstop
M574 Z2 S1 P"e1stop" ; configure active-low endstop for low end on Z2 via pin e1stop
M558 P5 C"zprobe.in" H5 F120 T3000 I1 ; BLTouch connected to Z probe IN pin, free up MOD pin
;M950 S0 C"zprobe.mod" ; servo/gpio 0 is Z probe MOD pin
;M280 P0 S10 ; send control signal to BLTouch through servo/gpio 0
G31 X-30 Y-15 Z0 P25 ; Probe Heights and ofsetts
M557 X20:170 Y20:200 S50 ; define mesh grid; Heaters
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
;M950 S0 C"^zprobe.mod" ; Duet Maestro BLTOUCH Servo Pin Mapping
M501
@gomond said in Z2 end stop won't appear in web interface:
M574 Z2 S1 P"e1stop" ; configure active-low endstop for low end on Z2 via pin e1stopThose lines are wrong. If the Z endstop switches are axis minimum endstops, it should be just one line:
M574 Z1 S1 P"zstop+e1stop" ; configure active-high endstops for low end on Z via pins zstop and e1stop
Make sure the order in which you give the two endstop pins in that command matches the order in which you give the corresponding Z motor drivers in your M584 command.
Thanks
I have made those changes now but still only see 0123 end stop switches in web interface and M119 still only returns X,Y,Z, Zprobe status.
See this thread https://forum.duet3d.com/topic/16201/endstop-on-2nd-y-motor/2.
