    WiFi reported error: Failed while trying to connect
    Firmware installation
    1.9k
    • thrawn86undefined
      thrawn86 @A Former User
      @bearer
      That was exactly what was on the board out of the box.
      e:
      M552 S0
      ok
      WiFi module started
      M588 S"*"
      ok
      M552
      WiFi module is disabled
      ok
      M111 P14 S1
      Debugging enabled for modules: WiFi(14)
      Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15)
      ok
      M552 S-1
      ok
      M552 S0
      WiFi:
      WiFi:  ets Jan  8 2013,rst cause:2, boot mode:(3,6)
      WiFi:
      ok
      WiFi: load 0x4010f000, len 1384, room 16
      WiFi: tail 8
      WiFi: chksum 0x2d
      WiFi: csum 0x2d
      WiFi: v3fff168c
      WiFi: ~ld
      WiFi module started
      G4 S1
      ok
      M587 S"Battlestar Pegasus Mainframe" P"***"
      ok
      M552 S1
      ok
      WiFi:
      WiFi: add if0
      WiFi: wifi evt: 8
      WiFi: scandone
      WiFi: ../src/SocketServer.cpp(353): found network dobry22
      WiFi: ../src/SocketServer.cpp(353): found network Alex WiFi
      WiFi: ../src/SocketServer.cpp(353): found network xfinitywifi
      WiFi: ../src/SocketServer.cpp(353): found network Brother Eye
      WiFi: ../src/SocketServer.cpp(353): found network luk-ela
      WiFi: ../src/SocketServer.cpp(353): found network PS4-A490FF8D684C
      WiFi: ../src/SocketServer.cpp(353): found network PS4-3B1F4A9CD2C0
      WiFi: ../src/SocketServer.cpp(353): found network Wifi is Jericho!!
      WiFi: ../src/SocketServer.cpp(353): found network Toilet Cam #12
      WiFi: ../src/SocketServer.cpp(353): found network Loki1
      WiFi: ../src/SocketServer.cpp(353): found network ATT528s735
      WiFi: ../src/SocketServer.cpp(353): found network The Room Of Requirement
      WiFi reported error: no known networks found
      WiFi module is idle
      WiFi: scandone
      WiFi: ../src/SocketServer.cpp(353): found network Petersen
      WiFi: ../src/SocketServer.cpp(353): found network SEC_LinkShare_836496
      WiFi: ../src/SocketServer.cpp(353): found network TK2.4
      WiFi: ../src/SocketServer.cpp(353): found network degapudi
      WiFi: ../src/SocketServer.cpp(353): found network CRAZYVirus
      WiFi: ../src/SocketServer.cpp(353): found network MAXIMUS
      WiFi: ../src/SocketServer.cpp(353): found network NETGEAR56
      WiFi module is idle
      WiFi: ../src/SocketServer.cpp(353): found network TP-LINK_D28A
      WiFi: scandone
      WiFi: ../src/SocketServer.cpp(353): found network NETGEAR20
      WiFi: ../src/SocketServer.cpp(353): found network Srbija 2G
      WiFi module is idle
      WiFi: scandone
      WiFi: ../src/SocketServer.cpp(353): found network Battlestar Pegasus Mainframe
      WiFi: ../src/SocketServer.cpp(353): found network BattlePi24
      WiFi: ../src/SocketServer.cpp(353): found network ATT3Hkz4Mq2.4
      WiFi: sleep enable,type: 2
      WiFi: wifi evt: 2
      WiFi: scandone
      WiFi: state: 0 -> 2 (b0)
      WiFi: state: 2 -> 0 (2)
      WiFi: reconnect
      WiFi: wifi evt: 1
      WiFi: STA disconnect: 2
      WiFi: scandone
      WiFi: reconnect
      WiFi: wifi evt: 1
      WiFi: scandone
      WiFi: reconnect
      WiFi reported error: Failed while trying to connect to Battlestar Pegasus Mainframe
      WiFi module is idle
      WiFi: wifi evt: 1
      WiFi: scandone
      WiFi: del if0
      WiFi: usl
      WiFi: mode : null
      WiFi: wifi evt: 8
      WiFi: mode : sta(bc:dd:c2:2d:5e:3e)
      WiFi: add if0
      WiFi: wifi evt: 8
      WiFi: scandone
      after that it just starts looping. Also, I was able to start it up in AP mode and I can get into DWC that way if needed.
      • A Former User?
        A Former User @thrawn86
        @thrawn86 is the network 2.4ghz?
        or maybe the SSID is too long for the firmware to handle, dc42?
        edit nvm, it finds the network but not on every scan, probaly poor signal quality.
        thrawn86undefined 1 Reply Last reply Reply Quote 0
        • thrawn86undefined
          @bearer
          to eliminate that possibility as well as the 2.4ghz issue (our network is simulcast 2.4/5.0) I created an entirely new 2.4ghz-only SSID with the same results.
          • A Former User?
            A Former User
            try running a wifi scanning app to see which channel is least congested and switch to that?
            • thrawn86undefined
              @bearer
              I moved the antenna as close as I could, it looks like it is pulling in Battlestar Pegasus Mainframe and BattlePi24 on every scan, both of which are broadcasting 2.4, and the latter is 2.4 only.
              2.4 is pretty crowded here but thats about the best I can do. It didn't seem to be a problem on my older duet with internal antenna.
              • A Former User?
                @thrawn86 said in WiFi reported error: Failed while trying to connect:
                all it takes is a new neighbor, its very unlikely both boards had a fault. maybe wifi and/or internal antenna isn't the best option for your location. (ed: or your router may be among a few that have shown to be incompatible with the ESP8266 chip, but if you haven't changed the router then odds are your environment changed. i.e. (new) neighbor with new wifi router causing poor signal)
