    DUAL EXTRUDER DUAL FAN
    • JVundefined
      JV
      HI GUYS
      I HAVE A DUAL EXTRUDER PRINTER AND EACH EXTRUDER HAS A ONE FAN.
      AS YOU WILL SEE IN MY CONFIG I MAPP EACH FAN FOR EACH TOOL (TOOL 0 FAN 0 AND TOOL 1 FAN 2 )
      WHEN I SEND A NEW PROGRAM TO THE PRINTER, WHEN IT STARTS TO PRINT THE SECOND LAYER, THE FAN1 NEVER TURN ON AND THE FAN 2 TURN ON AND IT DOESN'T STOP UNTILL THE MACHINE REACH THE END OF THE PROGRAM.
      WHEN I SEND M106 F0 S1 THE FAN0 TURN ON
      WHEN I SEND M106 F2 S1 THE FAN 2 TURN ON
      AND WHEN I SEND M107 ALL THE FANS TURN OFF
      ANY BODY CAN TELL ME WHY IT DOESN'T WORKS CORRECTLY WHEN IS PRINTING A PART?
      M106 P0 I1 F25000
      M106 P2 I1 F25000
      M563 P0 D0 H1 F0 S"DYZE1" ; Define tool 0
      G10 P0 X-45 Y0 Z0 ; Set tool 0 axis offsets
      G10 P0 R190 S225 ; Set initial tool 0 active and standby temperatures to 190C
      M563 P1 D1 H2 F2 S"DYZE2" ; Define tool 1
      G10 P1 X46 Y-0.5 Z0 ; Set tool 1 axis offsets
      G10 P1 R190 S225 ; Set initial tool 1 active and standby temperatures to 190C
      THANKS
        First off, please fix your CAPSLOCK key, as it appears to be stuck in the on position.
        Second, your config appears to be correct with Fan0 attached to Tool0 and Fan2 attached to Tool1.
        What slicer are you using? Can you provide a sample of gcode that shows how it's commanding the fans?
        JVundefined 1 Reply Last reply Reply Quote 1
        • JVundefined
          JV @Phaedrux
          hello @Phaedrux i'm using Simplify 3d and it doesn't support dual fan, so i try to do the configuration described in the tool definition chapter to avoid this problem.
          https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Tool_definition_section
          this is one example of gcode :
          Traffic_Cone_Rings_Orange.gcode
          Thankyou for your help
            There is something wrong with your simplify3d configuration. There is only a single M106 command in your gcode file. So it's not your duet configuration that is the problem. S3D is simply not controlling the fan.
