    SD Card Smoked and Burned
    434
    • skywurz
      skywurz last edited by
      Hello All
      I was setting up my new Duet 2 WIFI. I had been having issues with my end stops not working so i decided to go with stall detection. Everything seemed to be working fine i removed my end stop wires from the board and continued testing. when suddenly i started smelling smoke. I turned off the machine and found that the SD card was very hot (burned me a little when i ejected it) the SD card has clear heat damaged and looks like it started to burn. Now the board is not responsive. I unplugged everything (except the heated bed and hotend because they dont unplug) and tried to turn the system back on. after a few min i noticed a burning smell, my hot end was on full blast. Im not sure whats wrong any ideas? it will not connect to USB and when i plug in the SD card when it is on usb power it starts smoking again.
      • A Former User
        A Former User last edited by
        Sounds like a short to 3.3v.
        Please follow https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
        and share the status from each step. Take some pictures before disconnecting stuff as well, may come in handy later to try and prevent it from happening again.
        • chrishamm
          chrishamm administrators last edited by
          It sounds like your microSD card was excessively bent - in fact I had a similar problem with a damaged microSD card a while back. It became too hot to touch so I had to replace it. Does the board still turn on with the microSD card removed? Before you check that, please verify that there is no visible damage on the board.
          Duet software engineer
          • skywurz
            I already unplugged everything. when i plug in USB all of the lights seem to come on. IMG_20200507_122938.jpg I do not see any burned chips or anything like that IMG_20200507_122915.jpg
            • A Former User
              Maybe try firmware recovery but its a long shot.
              If anything on the board feels hot when running of USB then stop.
              Btw, just lighting or a hole?
              skywurz 1 Reply Last reply Reply Quote 0
              • skywurz
                skywurz @Guest last edited by skywurz
                @bearer said in SD Card Smoked and Burned:
                Ah yeah good catch i did not see that! Looks like a hole to me. IMG_20200507_130140.jpg
                I have tried 2 usb cables 2 computers and no dice on connectivity.
                A Former User 1 Reply Last reply Reply Quote 0
                • A Former User
                  A Former User @skywurz last edited by
                  @skywurz said in SD Card Smoked and Burned:
                  yeah, long shot. with a hole in U10 you woulnd't be able to run motors no matter what happened; odds are you'll need a couple of chips replaced.
                  • skywurz
                    Yeah trying the instructions when i jumper the erase pin i do not get the diag light and then the board starts smelling hot. the large chip becomes hot to the touch.
                    • skywurz
                      skywurz last edited by skywurz
                      For posterity here is the SD card
                      And a screen shot of my voltage from the web console
                      • skywurz
                        skywurz @skywurz last edited by
                        Just wanted to post an update. i have re-installed my old controller (Rambo) and swapped back all of my electronics and nothing seems a miss. I want to point out i had not changed any 5v connectors during the swap to or from the duet and i did not install or move any 24v connectors (bed,hotend) while the system was powered on.
                          Hi @skywurz, I'm sorry your board has failed. We'll give you the benefit of the doubt and provide a replacement under warranty. Please contact your supplier. If you bought it direct from Duet3D, https://www.duet3d.com/warranty.
                          • skywurz
                            skywurz @dc42 last edited by
                            @dc42 Thank You!!!
                            • skywurz
                              whelp it was a good run. I had my replacement running for a bit. I recently started having an issue with filament snapping so I decided to add a filament monitoring switch. 2 wire setup going from ground to e1 stop no center pin. I plugged it in and e1 fan started running. suddenly i noticed the wifi had no power. I unplugged the switch and reset the board still no wifi power led. I plugged in USB and nothing. This seems like exactly the symptoms as last time except I did not get a smoking hole in an SD card. Also happen right around when I hooked up my 3rd end stop. 🤷
                              o_lampe Phaedrux 2 Replies Last reply Reply Quote 0
                              • o_lampe
                                o_lampe @skywurz last edited by o_lampe
                                @skywurz
                                probably the endstop pinning is different between Ramps/Rambo-stuff and duet2 ?
                                Here's the duet2 wiring diagram
                                  Phaedrux Moderator @skywurz last edited by Phaedrux
                                  What is the endstop switch exactly and how exactly was it connected? Photos?
                                  Which fan do you mean exactly by e1 fan? Fan ports are fan0, fan1, fan2, and always on.
