    Newbie Seeking Help
    969
    • Danalundefined
      Danal
      Now is the time to follow this:
      https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
      You will already be at about step 6, with what you've done.
        When you type in just the IP address in the browser, what message does it report now? You may need to clear the browser cache.
        • turbo3000undefined
          turbo3000
          no errors in the browser when going the direct IP address.
          and strangely, it knows my assigned static IP address but it cannot remember it? maybe this is a firmware issue?
          I didn't have to send the M587 S & P command, it knows my static address, but when we run the M587, the SSID is remembered, but the IP is NULLED, yet the static IP address is there.
            turbo3000
            ok so i go to Step 8.
            Sent M552 S0
            then M552 S1 P192.168.1.120
            and now i get this... and even after 30seconds, i try M552 & it remains with those errors
              turbo3000
                Are you far away from the router?
                • ShaunCroundefined
                  ShaunCro
                  Have you tried reserving the IP on your router and allocating it to the Duet's mac instead of trying to specify on the device it self?
                  Your router isn't setup for any type of mac address authentication, or white listing is it?
                  Edit: have you updated the wifi server firmware? Think the latest is 1.23? NVM, missed that in initial post.
                  Try force your router to another channel as well, 1,6 or 11 would be the best as there is no overlap with other channels so should be better if there is an interference issue.
                  Lets just get one thing straight....
                  You don't own a Delta! It's true, you don't!
                  It owns you!
                    dc42 administrators @turbo3000
                    @turbo3000 said in Newbie Seeking Help:
                    That is asking to connect to the network whose SSID is "192.168.1.120", so it's not valid.
                      So it's working!
