    Newbie Seeking Help
    963
      jay_s_uk
      It does imply that.
      I would suggest copying everything off the SD card and formatting it with the SD card formatter https://www.sdcard.org/downloads/formatter/
      I would also suggest only copying across the /sys and /www folders.
      • turbo3000undefined
        turbo3000
        Thankyou. I have deleted those other files. Checked /sys folder again.
        But still no DWC !!!!
        PaulHewundefined 1 Reply Last reply Reply Quote 0
        • PaulHewundefined
          PaulHew @turbo3000
          @turbo3000 I would go back to basics. Please post your config.g just incase.....
          M588 "*"
          M587 with only the S & P parameters, so it gets the address from the router as opposed to being defined, just incase........................
          Get DWC working first then progress from that.
          So M20 "/www" does not show anything? It did on your post @ 16:40.:confused:
          Regards,
          Paul
            turbo3000
            ; Configuration file for Duet WiFi (firmware version 2.00)
            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri May 01 2020 01:28:58 GMT+1000 (Australian Eastern Standard Time)
            M550 P"My Printer" ; set printer name
            M667 S1 ; select CoreXY mode
            M552 S1 ; enable network
            ;M552 P192.168.1.120
            ;M554 P192.168.1.255
            ;M553 P225.255.255.0
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P2 S0 ; physical drive 2 goes backwards
            M92 X80.00 Y80.00 Z4000.00 E98.00 ; set steps per mm
            M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
            M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
            M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X330 Y330 Z400 S0 ; set axis maxima
            M574 X1 Y1 Z1 S0 ; set active low and disabled endstops
            M558 P5 H5 F0 T6000 ; set Z probe type to switch and the dive height + speeds
            G31 P600 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
            M106 P2 S1 I0 F500 H1 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
              Which browser are you using?
              Does it work any better if you enter this in the address bar:
              http://192.168.1.120/index.html
              PS - firmware version 2.0 is rather old!
                turbo3000
                i got something !!!!
                  I think the reason may be that the version of Duet Web Control you are using is much later than the version of the main firmware. Firmware 2.0 was designed to work with a much older version of DWC.
                  I suggest you upgrade to firmware 2.05.1. Download Duet2CombinedFirmware from https://github.com/dc42/RepRapFirmware/releases/tag/2.05.1 and copy it into /sys on the SD card. Put the card back in the Duet, start the Duet, and send M997 from YAT. After 30 seconds, reconnect form YAT and send M115 to see if the update was successful.
                    turbo3000
                    @dc42 said in Newbie Seeking Help:
                    M115
                    Ok the firmware update worked perfectly, however, this problem remains!
                      turbo3000
                      should i force the static IP in the config.h file?
                      • Danalundefined
                        Danal
                        Now is the time to follow this:
                        https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
                        You will already be at about step 6, with what you've done.
                          When you type in just the IP address in the browser, what message does it report now? You may need to clear the browser cache.
                            turbo3000
                            no errors in the browser when going the direct IP address.
                            and strangely, it knows my assigned static IP address but it cannot remember it? maybe this is a firmware issue?
                            I didn't have to send the M587 S & P command, it knows my static address, but when we run the M587, the SSID is remembered, but the IP is NULLED, yet the static IP address is there.
                              turbo3000
                              ok so i go to Step 8.
                              Sent M552 S0
                              then M552 S1 P192.168.1.120
                              and now i get this... and even after 30seconds, i try M552 & it remains with those errors
                                turbo3000
                                  Are you far away from the router?
                                  • ShaunCroundefined
                                    ShaunCro
                                    Have you tried reserving the IP on your router and allocating it to the Duet's mac instead of trying to specify on the device it self?
                                    Your router isn't setup for any type of mac address authentication, or white listing is it?
                                    Edit: have you updated the wifi server firmware? Think the latest is 1.23? NVM, missed that in initial post.
                                    Try force your router to another channel as well, 1,6 or 11 would be the best as there is no overlap with other channels so should be better if there is an interference issue.
                                    Lets just get one thing straight....
                                    You don't own a Delta! It's true, you don't!
                                    It owns you!
                                      dc42 administrators @turbo3000
                                      @turbo3000 said in Newbie Seeking Help:
                                      That is asking to connect to the network whose SSID is "192.168.1.120", so it's not valid.
                                        So it's working!
