    Hotend won't go above 177c
    109
    • tinfish340
      tinfish340 last edited by
      16.5 hours into a 17 hour print at 260c when the hotend plugged up.
      Fixed that and now I get a heater error at 177c. Replaced thermister and heater cartridge twice. No change. Checked all wiring. OK and everything ohm's out correctly.
      Ran PID and still errors at 177c. I increased the dead time to no avail.
      Everything has been running fine until now.
      Ver 1.23
      Any help is appreciated.
      • Danal
        Danal last edited by
        Any possibility of hot end fan, OR print fan, now being physically different where the air is going, as a side effect of that maint?
        I know some of my toolchangers won't act right, won't get hot as they should, when parked, because air "bounces off" the various things in the parking stall. The do fine when out.
        So airflow changes can make a huge difference.
        tinfish340 1 Reply Last reply Reply Quote 0
        • tinfish340
          tinfish340 @Danal last edited by
          @Danal No. Nothing has changed. I have done 60+ hour prints with this
          setup. That is what is baffling me. Power at the hot end maintains 24v.
            What error does it give?
            Can you post your config.g?
            What does your heater graph look like?
              If you dismantled the hot end, check that you have a gap between the top of the heater block and the bottom of the heatsink.
              • tinfish340
                tinfish340 @Phaedrux last edited by
                @Phaedrux Error: Heating fault on heater 1, temperature rising much more slowly than the expected 0.4°C/sec.
                ; generated by RepRapFirmware Configuration Tool v2 on Fri Mar 29 2019 23:01:22 GMT-0700 (Pacific Daylight Time)
                M111 S0 ; Debugging off
                G21 ; Work in millimetres
                M208 X330 Y300 Z375 S0 ; Set axis maxima
                M574 X1 Y1 Z1 S0 ; Define active low and unused endstops
                M558 P5 X0 Y0 Z1 H5 F200 T6000 ; Set Z probe type to analog, the axes for which it is used and the probe + travel speeds
                G31 X40 Y7 Z0.9 P50 ; Set Z probe trigger value, offset and trigger height
                				;Z-offset (Z0.9). Higher value LOWER nozzle height
                				;	   Lower value RAISE nozzle height
                M557 X10:340 Y10:240 S68 ; Define mesh grid
                M564 S0 H0
                M569 P0 S1 ; Drive 0 goes forwards - X
                M569 P1 S1 ; Drive 1 goes backwards - Y
                M569 P2 S0 ; Drive 2 goes backwards - Z
                M569 P3 S1 ; Drive 3 goes forwards - Extruder
                M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation 16
                M92 X160 Y800 Z1600 E90 ; Set steps per mm 16
                M566 X600 Y420 Z12 E120 ; Set maximum instantaneous speed changes (mm/min) - (JERK)
                M203 X6000 Y6000 Z500 E400 ; Set maximum speeds (mm/min)
                M201 X1000 Y1000 Z200 E250 ; Set accelerations (mm/s^2)
                M204 P1000 T1000 ; Set Max acceleration for P=printing moves and T=travel moves
                M906 X1600 Y1600 Z900 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M143 S285 ; Set maximum heater temperature to 285C
                ;M305 P1 X101
                M305 P1 T107000 B10832 C4.891620e-7 R4700 ; Set thermistor + ADC parameters for heater 0 - BED
                M305 P0 T99600 B4388 C0 R4700 ; Set thermistor + ADC parameters for heater 1 - HOTEND E3d
                M307 H0 P96.0, I3.285, D603.9 ;Bed
                ;M307 H1 P1.1, I0.011, D51.5 ;Hotend pid
                M307 H1 P17.8, I0.055, D74.9 ;Hotend E3d pid
                M563 P0 D0 H1 ; Define tool 0
                M550 P"Black Widow" ; Set machine name
                M552 S1 ; Enable network
                M586 P0 S1 ; Enable HTTP
                M586 P1 S0 ; Disable FTP
                M586 P2 S0 ; Disable Telnet
                M501
                ; Custom settings are not configured!
                  Phaedrux Moderator @tinfish340 last edited by
                  @tinfish340 said in Hotend won't go above 177c:
                  It looks like you have P1 and P0 flipped.
                  • tinfish340
                    Changed that around and ran PID auto tune and that fixed it.
                    Thanks for your help!!!
                    • tinfish340
                      So apparently that did not fix the problem. It did go up to 270C with no problems but upon printing there was almost no bonding between layers. The whole print just came apart. I feel like the problem lies within the board. How do you go from a perfectly good printer to junk when absolutely nothing changed as far as code goes? It will struggle to reach 210C now with no errors no matter how long it takes to get there.
                      FYI, I am using this. Flexion Dual Extruder
                        Where did you get the thermistor values?
                        If they are wrong, the displayed temp will not match the actual temp.
                        • tinfish340
                          This printer is a highly modified Black Widow that I have been using for years. Not much Black Widow left but these are the original settings. These settings have worked for a very long time until now. I also came up with the same settings when using the configurator. But I am open to anything that will get this working again.
                            Well what kind of thermistors are they?
                            This is a Duet Wifi with firmware 1.23?
                            • tinfish340
                              Gulfcoast Robotics 100K NTC 3950 - M3 Stud Screw-in thermistor and
                              I have also tried, not sure of the brand, NTC 3950 100K Thermistor with the glass end.
                              Duet WiFi Server Version: 1.23
                                Have you tried the values for NTC3950 100k thermistor?
                                You can also try deriving the values like so: https://www.jameco.com/Jameco/workshop/techtip/temperature-measurement-ntc-thermistors.html
