motor phase A/B disconnected on driver - AFTER single Z motor
I have this issue after switching my printer to a single belted Z motor. The Z will not move at all and will spam Motor Phase A/B disconnected in the console. I plugged the other motor back in and now it works fine. Is there some setting I need to change? After searching I see some mention of jumpers - but I don't see anywhere to place jumpers nor do I remember seeing any with my duet.
FW info:
Firmware Version: 2.05 (2019-12-13b1)
WiFi Server Version: 1.23
Web Interface Version: 1.22.3 -
https://duet3d.dozuki.com/Guide/2.)+Wiring+your+Duet+2+WiFi-Ethernet/9
Top right corner of the DUET board in the image shows jumper placement.
Ah i see. So I just need to make a jumper to short the outer 2 pins together? just want to confirm before I go shorting things lol.
