Cannot connect with Orange Livebox
Good morning all,
Small gaps concerning me with the wifi connection of the duet 2 wifi
In YAT via command M552 S1 I always get the same result
WiFi reported error: Failed while trying to connect to Livebox-CE4A
WiFi module is idle
This even by putting the livebox in association
So we can see that the livebox is well detected by the duet card
I specify that ssid and the password are correctAt this stage it is therefore impossible to connect to the livebox
So I go to the box management page via the browser => advanced configuration => DHCP
big disappointment no duet detectedHas anyone had this problem?
Finally when I connect this router to the livebox and from YAT => M552 S1
No problem the connection is done in 2 seconds
WiFi module is connected to access point dlink, IP address xxx.xxx.x.xxxSo here is my 2nd question Do you have to go through an external router to the livebox?
And one more question: does this problem exist on other boxes?
I've not heard of an issue with Orange Livebox before. However, a search for "esp8266 orange livebox" returned some hits for problems that people had reported.
How close is the Duet to the Livebox? Perhaps the WiFi signal strength is too low.
I've replied to your other thread as well. https://forum.duet3d.com/topic/16353/connection-impossible-avec-livebox-orange?_=1589483501852
Please try not to double post. Posting in english will probably get you more replies, but posting in your native language is alright too.
Ok thanks i take note
Yes i know it's very sturdy
For the distance between the devices about 2 meters but and it is sufficient since the duet detects the good ssid (Livebox-CE4A)And onc if I understand correctly, no need for an external router it should connect directly to the livebox
Thank you all the same on my side I continue the research
Thanks for that info, perhaps that will help others who have a ISP provided wifi router.
