DWC Loading Issue
Recently for some reason, my DWC looks like this after loading. After a couple of refresh or restart, the proper GUI can show up. I am using Chrome and a Duet3 running standalone mode with wired internet.
It seemed happen when I use the "printername".local address. The GUI loads fine with the IP address.
Here is my config.g; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed Apr 01 2020 22:14:44 GMT-0500 (Central Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"IDEX" ; set printer name M575 P1 B57600 S1 ; Network M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S1 D3 ; physical drive 0.0 goes forwards M569 P0.1 S1 D3 ; physical drive 0.0 goes forwards M569 P0.2 S0 D3 ; physical drive 0.2 goes forwards M569 P0.3 S1 D3 ; physical drive 0.3 goes forwards M569 P0.4 S0 D3 ; physical drive 0.4 goes forwards M569 P0.5 S0 D3 ; physical drive 0.5 goes forwards M584 X0.0 U0.1 Y0.2 Z0.3 E0.4:0.5 ; set drive mapping M350 X16 U16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation M92 X200.00 U200.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm M566 X900.00 U900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 X9000.00 U9000.00 Y6000.00 Z1500.00 E1200.00:1200.00 ; set maximum speeds (mm/min) M201 X1500.00 U1500.00 Y1500.00 Z1000.00 E250.00:250.00 ; set accelerations (mm/s^2) M906 X600 U600 Y1300 Z600 E600:600 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X-30 U26 Y0 Z0 S1 ; set axis minima M208 X260 U316 Y190 Z186.7 S0 ; set axis maxima ; Endstops M574 X1 P"io1.in" S1 ; configure sensorless endstop for low end on X M574 U2 P"io2.in" S1 M574 Y2 P"!io5.in" S1 ; configure sensorless endstop for low end on Y M574 Z2 P"io6.in" S1 ; configure sensorless endstop for low end on Z M915 P0:1 S10 R1 M915 P2 S10 R1 ; Z-Probe M558 P1 I0 C"!io3.in" A5 R0.4 H6 F1300 T6000 ; set Z probe type to switch and the dive height + speeds G31 P220 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height ;G31 P{sensors.probes[0].value[0] + 30} ;G31 X0 Y0 Z0 M557 X70:220 Y30:180 S75 ; define mesh grid ; Heaters M570 S99999 M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M143 H0 S80 ; set temperature limit for heater 0 to 120C M307 H0 B0 S0.8 ; enable bang-bang mode for the bed heater and set PWM limit M307 H0 A84.5 C473.8 D1.4 M140 H0 ; map heated bed to heater 0 M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M143 H1 S240 ; set temperature limit for heater 1 to 240C M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M307 H1 A593.7 C179.8 D9.3 V24.0 M308 S2 P"temp2" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin temp2 M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2 M143 H2 S240 ; set temperature limit for heater 2 to 240C M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M307 H2 A532.1 C165.0 D10.3 V24.0 M572 D0:1 S0.1:0.1 ;Pressure Advance ; Fans M950 F0 C"out7" Q500 ; create fan 0 on pin out4 and set its frequency M106 P0 L1.0 S0 H1 T60 S1.00 ; set fan 0 value. Thermostatic control is turned on M950 F1 C"out8" Q500 ; create fan 1 on pin out5 and set its frequency M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off M950 F2 C"out4" Q500 ; create fan 2 on pin out7 and set its frequency M106 P2 L1.0 S0 H2 T60 S1.0 ; set fan 2 value. Thermostatic control is turned on M950 F3 C"out9" Q500 ; create fan 3 on pin out6 and set its frequency M106 P3 S0 H-1 ; set fan 3 value. Thermostatic control is turned off ; Tools M563 P0 D0 H1 F0:1 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 D1 H2 X3 F0:3 ; define tool 1 G10 P1 U-0.0 Y1.0 Z-0.2 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C ; Custom settings are not defined T0
What firmware and DWC version?
@Phaedrux
DWC version: 2.1.5
RRF version: 3.0.1 RC-11
Please update to the 3.01 full release and see if you still have issues.
