Probing speed tied to X position
  • The probing speed on my printer sometimes depends on the X position of the print head. When the head is at x0, probing is significantly slower than the requested value. When the head is at X max, probing is significantly faster.
    The thing is, the issue doesn't occur all the time. Sometimes it goes away after a firmware update, sometimes it doesn't.
    RRF 3.01 RC12
    Config.g:
    ; Configuration file for Duet Maestro (firmware version 3)
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Jan 20 2020 18:17:29 GMT+0100 (Central European Standard Time)
    G90                                                    				 ; send absolute coordinates...
    M83                                                   				 ; ...but relative extruder moves
    M550 P"Print-a-Reeno"                                 				 ; set printer name
    M552 P0.0.0.0 S1                                      				 ; enable network and acquire dynamic address via DHCP
    M586 P0 S1                                            				 ; enable HTTP
    M586 P1 S0                                            				 ; disable FTP
    M586 P2 S0                                            				 ; disable Telnet
    ; Motors
    M569 P0 S1 D3 F3 B2 Y1:3 V1000000              						 ; physical drive 0 goes forwards
    M569 P1 S1 D3 F3 B2 Y1:3 V1000000              						 ; physical drive 1 goes forwards
    M569 P2 S1 D3 F3 B2 Y5:1 V0                   						 ; physical drive 2 goes forwards
    M569 P3 S0 D3 F3 B2 Y0:3 V1000000           								 ; physical drive 3 goes backwards
    M569 P4 S1 D3 F3 B2 Y5:1 V0                    						 ; physical drive 4 goes forwards
    M584 X0 Y1 Z2:4 E3                                    				 ; set drive mapping
    M671 X-37.5:291 Y105:105											 ; define z leadscrew positions for gantry levelling
    ; Motion
    M350 X16 Y16 Z16 E16 I1  	                             			 ; configure microstepping with interpolation
    M92 X100.00 Y100.00 Z400.00 E950.3                					 ; set steps per mm
    M566 X1000.00 Y1000.00 Z24.00 E3000.00               					 ; set maximum instantaneous speed changes (mm/min)
    M203 X24000.00 Y24000.00 Z1000.00 E10000.00            				 ; set maximum speeds (mm/min)
    M201 X3000.00 Y3000.00 Z200.00 E3000.00               				 ; set accelerations (mm/s^2)
    M906 X700 Y700 Z400 E800 I30                          				 ; set motor currents (mA) and motor idle factor in per cent
    M84 S70                                               				 ; set idle timeout
    M572 D0 S0.06                                     	    			 ; set extruder 1 pressure advance
    M207 S0.8 F3000 T1500 Z0.6                    		          		 ; set G10 retraction parameters
    M208 X0 Y-4 Z-2 S1                           	     	        	 ; set axis minima
    M208 X250 Y210 Z213 S0                                  	         ; set axis maxima
    M574 X1 S1 P"xstop"                         	            		 ; configure active-high endstop for low end on X via pin xstop
    M574 Y1 S1 P"ystop"                       	                		 ; configure active-high endstop for low end on Y via pin ystop
    M574 Z1 S2                                 	                		 ; configure Z-probe endstop for low end on Z
    M591 D0 P2 C"e0_stop" S1                 	                		 ; configure filament runout sensor
    M558 P1 C"zprobe.in" H2 F900 T6000 A5          		        		 ; set Z probe type to unmodulated and the dive height + speeds
    G31 P500 X0 Y0 Z0.2                             	        		 ; set Z probe trigger value, offset and trigger height
    M557 X12.3:215 Y1.5:197.6 P5:5                         	      		 ; define bed probe grid
    M376 H10                                              				 ; define where bed mesh compensation tapers off
    M308 S0 P"bedtemp" Y"thermistor" T100000 B3950  					 ; configure sensor 0 as thermistor on pin bedtemp
    M950 H0 C"bedheat" T0 Q60000                           	     		 ; create bed heater output on bedheat and map it to sensor 0
    M143 H0 S125                                         		         ; set temperature limit for heater 0 to 125C
    M307 H0 B0 S1.00                                   	        		 ; disable bang-bang mode for the bed heater and set PWM limit
    M140 H0                                            	        		 ; map heated bed to heater 0
    M570 H0 P10 T15 S5                                          	     ; set heater 0 fault conditions
    M308 S1 P"e0temp" Y"thermistor" T68410.97 B4264.71 C0.7000824743e-7	 ; configure sensor 1 as thermistor on pin e0temp
    M950 H1 C"e0heat" T1                              	        		 ; create nozzle heater output on e0heat and map it to sensor 1
    M143 H1 S285                                       	        		 ; set temperature limit for heater 1 to 275C
    M307 H1 B0 S1.00                    	               		         ; disable bang-bang mode for heater  and set PWM limit
    M570 H1 P10 T5 S5                           	                	 ; set heater 1 fault conditions
    M302 S175 R80                                        	         	 ; set minimum extrusion and retraction temperature
    M950 F0 C"fan0" Q60000                              	        	 ; create fan 0 on pin fan0 and set its frequency
    M106 P0 S0 H-1                                      	        	 ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"fan2" Q60000                             		 ; create fan 1 on pin fan2 and set its frequency
    M106 P1 S1 H1 T45                                  	       		 	 ; set fan 1 value. Thermostatic control is turned on
    M563 P0 S"Skelestruder" D0 H1 F0                       	        	 ; define tool 0
    G10 P0 X0 Y0 Z0                                   	       		 	 ; set tool 0 axis offsets
    G10 P0 R0 S0    					        						 ; set initial tool 0 active and standby temperatures to 0C
    ; Custom settings
    M912 P0 S-6.8                                          	        	 ; calibrate MCU temperature
    M308 S2 Y"mcu_temp" A"MCU"											 ; show MCU temperature in graph
    M200 D1.75                                          	        	 ; set default filament diameter
    M918 P1 E-4 F2000000                                   				 ; configure direct-connect display
    M501                                                  	        	 ; load saved parameters from non-volatile memory
    T0                                                    				 ; select first tool
    Bed.g:
    ; bed.g
    G30 P0 X0 Y105 Z-99999
    G30 P1 X101 Y105 Z-99999
    G30 P2 X206 Y105 Z-99999 S2
    G29
    G1 X0 Y0 F6000 ; return to 0:0
  • Moderator
    Do you have a M558 command in your homing files or other files that modifies the probing feed rate?
  • I don't think so. Also the issue does happen during both gantry levelling and mesh bed measurement
  • I used to have a m558 in bed.g but deleted it about a month ago
  • Moderator
    What type of probe is it?
  • @Phaedrux 8mm inductive. The exact model is Prusa PINDA 1.
  • Moderator
    I think you should be using probe type 5 (simple switch), not probe type 1 (analogue).
    https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_NPN_output_normally_open_inductive_or_capacitive_sensor
  • OK, I changed the probe type to 5. The speed deviations are still there, however.
  • Moderator
    @Matej101 said in Probing speed tied to X position:
    H2 seems a little low for a dive height. Try H5. Maybe it's too close.
