Core XYU or XYUV
@curlypaul I'll have to sleep on it. I can't get my head around why it all works fine during homing but after homing, the exact same commands as used in homing make things go haywire. Just doesn't make any sense........
@deckingman - No
I've had enough for today anyway ! -
@curlypaul said in Core XYU or XYUV:
This
.. the UV motors are still not moving after homing, motor current is definitely reduced as now 'x' carriage twitches as I try to move Y
seems to me like my dual gantry CoreXYUV. Where "normal movement" is with multiple motors mapped to axes. But to home them I map individual motors to individual axes, home them, then re-combine them.
So my config.g starts with this (actually it's CoreXYUVAB - just ignore the AB)
M584 X3.2:0.0:0.2 Y3.1:0.1:0.3 Z3.0 U0.0 V0.1 A0.2 B0.3 E1.0:1.1:1.2:2.0:2.1:2.2 P7
I also use M669 with custom matrix for the AB gantry but that's of no concern here.It's also RRF 3 so the motors are defined by Board:Position (3.2 means driver2 on expansion board 3).
As you can see, it start with U and A also mapped to X, and V and B mapped to Y.
Then at the start of my home all, to home X and Y I do this:
M584 X3.2 Y3.1; temporarily map X3.2 and Y to 3.1 onlyThat removes the U and A from X and the V and B from Y.
So then I home X,Y U,V A and B individually.Then I recombine U and A with X, and V and B with Y and hide those other axes using this.
M584 X3.2:0.0:0.2 Y3.1:0.1:0.3 P3So I'm pretty sure you need to do something long those lines for your V and Y axis. But your X and U need to run independently and I don't know how to handle that combination.
Maybe it isn't CoreXYUV in the true sense and you need to use M669 with some weird matrix (but then DC said it was CoreXYUV).
Not sure if I need sleep now or caffeine
Some progress today
Update on previous first though, Adding actual endstops make no difference
My issue still appears that in CoreXYUV - M669 K8 - After homing X,Y, and U My 'V' axis motors do not move when Y is commanded. As a note though the UV Motors do move and correctly when homing YSo, clutching at my last remaining straws, I tried CoreXYU/K5 mode, It's working as it should
I'm baffled - I'm going with it for the time being to move onto wiring it all up
I've atttached files, just in case anyone can see something blindingly obvious, as I still can't
@curlypaul It makes sense to me, because you don't have a separate "V" axis. That is to say, Y and V are one and the same thing. So logic would dictate that it ought to be CoreXYU. But DC said it should be CoreXYUV and he wrote the firmware so he should know (unless he just didn't look closely enough to spot your common gantry? ). I don't enough about the kinematics matrices to make any sort of informed judgement.
User @wilriker told me what command to use in my CoreXYUVAB which is this:
M669 K8 A0:0:0:0:0:1:1 B0:0:0:0:0:1:-1........but I have no idea how he arrived at the values for A and B - I just put in what he told me and it works. Not that any of this is relevant to your situation.......
Quick update.. All running on well on 2.02 for some strange reason, but have managed a couple of dual colour prints..!
Few things to sort out, but getting there bit by bit
@curlypaul Congrats! Those prints don't look to scruffy at all!.
@deckingman - Thankyou
Not too bad - bit of tuning required i'll admit, but very happy so far
Hi, very good job, and very beautiful aluminium parts.
@deckingman said in Core XYU or XYUV:
olding curre
I found this very helpful. I think...lol...I want to say thanks for all before I do ask for anything though. I've built a corexyu with one gantry, but two independant carriages, both connected to two motors in corexy mode, for a total of four motors running two carriages on one gantry. I've been using Marlin for a few years now, but RRF has me flumuxed. Did you ever figure out all the files, and if so, would you mind sharing? I'm still confused about a lot of the basics...ie what is an axis in regard to motors on the same x or y movement?? LOL...I'm definitely a nube to reprap but not programming. I'm using a duet 2 wifi and duex5 -
Hi curlypaul, I hope you are still connected, I am experiencing similar problems with my Core XYU.
https://forum.duet3d.com/topic/22176/core-xyu-z-movement-issue/11?_=1615984614686.If you are still out there could you send over a copy of your final config.g please?
