    Short to fan 2
    • claustroundefined
      claustro
      Hi , during some testing I made a short between the 2 wires coming from fan 2 . I heard a small pop and now Fan 2 isnt' working anymore.
      Do you have any idea if is it possible to repair it?
      I can't see clearly sings of burns , my only doubt is regarding the component show in this picture.
        If it's only Fan2 that doesn't work then the mosfet you indicate is almost certainly blown. See https://duet3d.com/wiki/Connector_and_spare_part_numbers for replacement part numbers.
        Removing TR1 from the board without damaging the PCB is difficult without hot air desoldering equipment, because you need to heat all 3 pads at the same time to avoid lifting the PCB traces.
        • claustroundefined
          claustro
          Thank you very much for your answer yes is pnly fan 2 blow,
          I have an hot air desoldering gun but not an heated bed except the one of another printer 🙂
          I am planning to cover all the area with heat resistent kapton adesive and then replace the mosfet.
          Can you suggest me the best temperature of hot air gun ?
          Is this the right one?
          http://www.ebay.it/itm/NXP-PMV40UN2-MOSFET-Transistor-N-Channel-4-4-A-30-V-0-036-ohm-4-5-V-/182121436664?hash=item2a674895f8:g:bikAAOSwhRxXLLc6
            Yes that's the right mosfet. The main component you need to protect from the heat is the adjacent white Molex connector. The heat may melt the solder on adjacent components too, so lift the old mosfet off with tweezers when the solder has melted and avoid jogging the board. It's easier to use a fine tipped soldering iron to solder on the new one then to use hot air.
            I suggest an air temperature of about 260C to desolder the old one. A heater under the PCB isn't essential when replacing small components like that one.
            • claustroundefined
              claustro
              thank you very much.
              • claustroundefined
                claustro
                Procedure completed.
                thx for your assistance.
                Andrea
