    z probe wont respond to G31
    1.1k
    • ziggymanpopoundefined
      ziggymanpopo
      im wondering why if i change the settings in G31 for my z probe why would the height not change if i change the z value in G31
      ; M558 P5 H5 F100 T2000 ; Set Z probe type to capasitive and the dive height + speeds
      M558 P5 H5 F100 T4000 ; Set Z probe type to capasitive and the dive height + speeds
      G31 P500 X-42 Y-5 Z7.75
      my problem is in doing somthing wrong calibrating the offset i must be in the wrong spot??
      been thru it now 4 time just dont see it one of you suggested an other command ?? def. lost
      🙃 maybe if i look at it this way lol
      • chrishammundefined
        chrishamm administrators
        Maybe you're using config-override.g and there is still one defined in there? Does it work when you execute it from the DWC console?
        Duet software engineer
          ziggymanpopo
          thats where im changing it from the dwc,, funny thing ive allways had this prob.
          there is no config.goveride file at all in my system.
          baby stepping quit working when i changed to the v2 interface it only works if the printer isnt running a file weird ??
          i have never been able to get an offset entered
          • Stephen6309undefined
            Stephen6309
            Make sure you don't have a G31 later in config.g. I use a macro to set it, since I use a few different filaments that use different temperatures. Like PLA and PETG.
              ziggymanpopo
              No other entires just in config.g
                ziggymanpopo
                Is G 31 the place i need to set my off
                set?? Im not sure at all
                  Do you have a G31 in your homing files or beg.g?
                    ziggymanpopo
                    No more entries in any other files that i know of.
                      1. Is it the height after homing Z that isn't changing? If so then that may indicate an error in your homeall.g and/or homez.g files.
                      2. What Duet and firmware version are you using?
                        ziggymanpopo
                        i believe the corect anser to be ver1.12
                        also remeber ihad to reload my www. file
                        so ver1.12. with the v2 dwc interface. would that be correct?
                        heres the config g < home all< and the home z files for you to see
                        ( ill remove G29 S1 )
                        ; generated by RepRapFirmware Configuration Tool on Thu Sep 06 2018 21:21:12 GMT-0700 (Pacific Daylight Time)
                        M550 Pe3 ; Set machine name
                        M552 S1 ; Enable network
                        M586 P0 S1 ; Enable HTTP
                        M586 P1 S0 ; Disable FTP
                        M586 P2 S0 ; Disable Telnet
                        M569 P0 S0 ; Drive 0 goes forward
                        M569 P3 S1 ; Drive 3 (Extruder 0) goes backwards
                        ; M92 X79.7 Y320 Z400.4 E96 ; Set steps per mm
                        M92 X79.2 Y320 Z400.5 E96 ; Set steps per mm
                        M566 X1600 Y500 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
                        M203 X30000 Y1600 Z300 E1500 ; Set maximum speeds (mm/min)
                        M201 X500 Y500 Z300 E5000 ; Set accelerations (mm/s^2) is 500
                        M906 x950 Y1200 Z850 E950 I30 ; Set motor currents (mA) and motor idle factor in per cent
                        M84 S300 ; Set idle timeout
                        ; M208 X-5.5 Y-10 Z0 S1 ; Set axis minima
                        ; M208 X495 Y495 Z460 S0 ; Set axis maxima
                        M208 X500 Y500 Z500 S0 ; Set axis maxima
                        M574 X1 Y1 Z1 S1 ; Set endstops controlled by sw. x controlled by capasitive sensor
                        G31 P500 X-42 Y-5 Z7.75 ; Set Z probe trigger value, offset and trigger height - is Nozzle higer
                        M557 X15:215 Y35:215 S20 ; Define mesh grid
                        M143 H0 S120 ; Set temperature limit for heater 0 to 80C
                        M305 P1 T100000 B4400 R4700 ; Set thermistor + ADC parameters for heater 1
                        M143 H1 S280 ; Set temperature limit for heater 1 to 240C
                        ; M307 H1 A245.3, C121.7, D4.0, S0.5 ; PID
                        ; M106 P0 S1 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                        ; M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                        home all; Tools
                        M563 P0 D0 H1 ; Define tool 0
                        ; Enable Bed Leveling
                        G29 S1 ; Enable Mesh Bed Leveling
                        Home All
                        G91 ; relitave mode
                        G1 S2 Z4 F3000 ; raize head 4mm
                        G1 S1 X-500 Y-600 f3000 ; move y and x to endstops in -neg direction until end sw trip
                        G1 S2 X4 Y4 f600 ; move slowly 6mm in + direction
                        G1 S1 X-10 Y-10 ; move up to 10mm in the Y- andX- directions untill the homming switches are trigered
                        G90 ; back to absolute mode
                        G1 X125 Y125 F3000 ; put head at fist probe piont
                        G30 ; lower head , stop when z probe is trigered
                        home z
                        ; homez.g
                        ; called to home the Z axis
                        G91 ; relative positioning
                        G1 Z2.5 F6000 S2 ; lift Z relative to current position
                        G90 ; absolute positioning
                        G1 X51 Y20 F6000 ; go to first probe point
                        ;G91 ; relative positioning
                        ;G1 S2 Z2.5 F100 ; lift Z relative to current position
                        ;G90 ; absolute positioning
                          ziggymanpopo
                          also just found this file called bed g.
                          G29 ; probe the bed and enable compensation
                          not sure, but is this for slicer start code??
                            ziggymanpopo
                            will this also add another error for z offset or ??? is this one o k in its separate system fie
                              ziggymanpopo
                              lets start over new thread
                              re ask the question
                              this is where im at
                              duet reports z at 12.75 after homeing
                              trigger height is at 7.75
                              zerro is at is at 6.30
                              during a print the duet throws back the Z tool position as 1.42 with the nozzle burried in the glass
                              in my mind all Entries are a positive #
                              Z-Probe
                              G31 P500 X-42 Y-5 Z7.75 ; Set Z probe trigger value, offset and trigger height - is Nozzle hoger
                                ziggymanpopo
                                is this my error ...Z7.75 should it read Z-7.75 is it a flipin - that been hanging Me???
                                • aidarundefined
                                  aidar
                                  I dont know if it is related to your problem or not, but you should remove G29 S1 from config.g. You can not enable mesh compensation before homing. G29 should come after homing, not before.
                                    ziggymanpopo
                                    i believe its commented out wouldn't that do the same
                                    • aidarundefined
                                      aidar
                                      @ziggymanpopo said in z probe wont respond to G31:
                                      Does not seems to be commented out.
                                        ziggymanpopo
                                        ;G29 S1
                                          ziggymanpopo
                                          think i did it right after im just stumped?? are my settings right ??
                                            ziggymanpopo
                                            other than that ??
