Problem when Homing X & Y "Alone"
Recently I noticed that when I home X or Y, after it homed, my carriage move more on the X Axis.
When I home All it works great.
Also when I finish a print it homes to -2.5mm on the X-Axis.
I honestly do not know what causes this.
Here is my HomeX:; homex.g
; called to home the X axis
; generated by RepRapFirmware Configuration Tool v2.1.3 on Sat Nov 30 2019 14:18:00 GMT-0500 (heure normale de l’Est nord-américain)
G91 ; relative positioning
G1 H1 X-335 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F6000 ; go back a few mm
G1 H1 X-335 F360 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioningThanks you
Please post your other homing files and your config.g
What kind of a printer is it?
What firmware version are you using?
What Duet board?
I own a home built CoreXY with a DuetWifi
Config
; generated by RepRapFirmware Configuration Tool v2.1.3 on Sat Nov 30 2019 14:17:59 GMT-0500 (heure normale de l’Est nord-américain); General preferences
M550 P"My Printer" ; set printer nameM667 S1 ; select CoreXY mode
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P3 S0 ; physical drive 3 goes forwards
M92 X160.00 Y160.00 Z800.00 E837.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X330 Y270 Z295 S0 ; set axis maxima; Endstops
M574 X1 Y2 S1 ; set active high endstops
M574 Z1 S2 ; set endstops controlled by probe; Z-Probe
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y40 Z0 ; set Z probe trigger value, offset and trigger height
M557 X15:315 Y40:265 S20 ; define mesh grid; Heaters
M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
HomeY
; homey.g
; called to home the Y axis
G1 H1 Y285 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 H2 Y-5 F6000 ; go back a few mm
G1 H1 Y285 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioningHomeAll
; homeall.g
; called to home all axes
G1 H1 X-335 Y285 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-335 ; home X axis
G1 H1 Y285 ; home Y axis
G1 X5 Y-5 F6000 ; go back a few mm
G1 H1 Y285 ; then move slowly to Y axis endstop
G1 H2 X15 Y15 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 S2 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning
@Nylkos said in Problem when Homing X & Y "Alone":
Do not use H2 in that command in homeall. Remove the H2. You should also position the probe in the center of the bed rather than the corner.
Also, remove the H2 from the second move to back away from the endstop. It's not needed after the axis is homed once, and on a corexy printer the H2 will move the independent motor, which can cause issues.
From homex and homey
G1 H2 X5 F6000 ; go back a few mmNote that homeall doesn't have the H2 on the X and Y moves.
You're missing a trigger height in this command. See here: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
