troubleshooting Duet2 WiFi Z driver
Hi all, i recently purchased a Duet2 Wifi and Duet 5 and have got to the point of testing motors through macros. the Z motors I have work fine on any other output on the duet2 wifi board but I get absolutely nothing out of the Z. the driver chip gets warm to the touch but no power out?
any help appreciated!
Any error messages in the gcode console?
Can you post your config.g?
Are these dual Z motors or just one? If just one are the jumpers installed on the second Z port?
When and where did you purchase it?
@Phaedrux
i was just running it with the basic setup with jumpers. set up through the reprap configurator.; Configuration file for Duet WiFi (firmware version 2.03)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Apr 20 2020 19:29:39 GMT-0700 (Pacific Daylight Time); General preferences
M550 P"printer who shall be named" ; set printer nameM667 S1 ; select CoreXY mode
M551 P"" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X610 Y838 Z458 S0 ; set axis maxima; Endstops
M574 Z1 S0 ; set active low and disabled endstops
M574 X1 Y1 S3 ; set endstops controlled by motor stall detection; Z-Probe
M558 P5 R0.4 H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:600 Y15:810 S60 ; define mesh grid; Heaters
M305 P0 X500 R4700 ; configure PT1000 for heater 0
M143 H0 S185 ; set temperature limit for heater 0 to 185C
M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 S"test tool" D0 H1 F0 ; define tool 0
@koda2216 said in troubleshooting Duet2 WiFi Z driver:
Are you sure that 4000 steps per mm is correct for your z axis arrangement?
@Phaedrux
purchased through filastruder april 16th
@Phaedrux
no, but its also not set built completely yet, this was just a bare motor not connected to anything. they are the super whopper motors they work on other outputs using the "M584 X0 Y1 Z3:4:5:6" and running "g1 s2 z100 f3000"
Please try 400 for the steps per mm with the motor connected to the Z driver just to eliminate any issues arising from using such a high steps per mm (like stalling).
is there a way to verify that it took my config.g file with the changed steps? new config.g file. ran code
g91
g1 s2 z100 f3000no movement
new code uploaded through dwc.
M551 P ; set password
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M84 S30 ; Set idle timeout
You can send most gcodes without any parameters in the console and it will report back with the currently used values.
Can you also send M122 and post the result?
@Phaedrux
8:25:00 PMM122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later + DueX5
Board ID: 08DLM-996RU-N8PS0-7JKDG-3S46S-TV93N
Used output buffers: 3 of 24 (16 max)
Static ram: 25680
Dynamic ram: 94168 of which 396 recycled
Exception stack ram used: 332
Never used ram: 10496
Tasks: NETWORK(ready,660) HEAT(blocked,1236) DUEX(suspended,156) MAIN(running,3756) IDLE(ready,160)
Owned mutexes:
Last reset 00:10:52 ago, cause: software
Last software reset at 2020-05-19 20:14, reason: User, spinning module GCodes, available RAM 10516 bytes (slot 0)
Error status: 8
Free file entries: 10
MCU temperature: min 43.1, current 43.7, max 43.8
Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
Driver 5: standstill, SG min/max not available
Driver 6: standstill, SG min/max not available
Driver 7: standstill, SG min/max not available
Driver 8: standstill, SG min/max not available
Driver 9: standstill, SG min/max not available
Date/time: 2020-05-19 20:24:59
Cache data hit count 2545255665
Slowest loop: 2.94ms; fastest: 0.08ms
Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== DDARing ===
Scheduled moves: 1, completed moves: 1, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 201.13ms; fastest: 0.08ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
Failed messages: pending 0, notready 0, noresp 1
WiFi firmware version 1.23
WiFi MAC address bc:dd:c2:31:a3:a5
WiFi Vcc 3.39, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 22824
WiFi IP address 10.0.0.10
WiFi signal strength -76dBm, reconnections 0, sleep mode modem
- WiFi -
Do you have 4 motors connected, or just the one?
I'm thinking your Z driver may not be working unfortunately.
You say the motors work on 3:4:5:6 but not 2?
And you've tried another motor on 2?
@Phaedrux
I have 4 z motors they work on drives 3:4:5:6 when I run the command m584 x0 y1 z3:4:5:6. no matter what I do even with jumpers and running the command m584 x0 y1 z2 I get nothing. just the driver chip gets hot but no movement.
Understood. Please hang on while we see if DC42 has any other ideas.
I agree, I think the Z driver has failed, and I approve a warranty replacement.
@dc42 thank you guys for your help!
