    Berd air connection to heater pin
    • matej1006undefined
      matej1006
      Hello will this code work that i will be able to connect berdair pump to heater 1 pin's?
      my 4 heater are all connected to duex board so i have bouth Heater on duet2wifi free
      ; Part cooling fan
      M950 H1 C"nil" ; disable heater 1 and free up the associated pin
      M950 F9 C"heater1" Q0; Fan 9 is connected to heater 1 pin, PWM at 100Hz
      M106 P9 S1
      i have H1 heater sign to duex.e2heat
      so i need to sign new heater and then disable pin or how i could manage that?
      and what i need to do that i will see fan on dashboard?
      Matej
        If the Berd Air is your main print cooling fan, it's best to call it Fan 0 not Fan 9. Don't create heater 1. So I suggest you use the following:
        M950 F0 C"duex.e2heat" Q100; Fan 0 is connected to duex.e2heat pin, PWM at 100Hz
        M106 P0 S1
        The fan should appear on the dashboard automatically.
        You should connect a flyback diode in parallel with the Berd Air motor, because the heater outputs on the Duet don't have built-in flyback diodes.
          matej1006
          hello @dc42 i add diode already where can i find all connector name
          And which is gnd and vcc pin or how i need to connect Motor to heater pin
          • deckingmanundefined
            deckingman @matej1006
            @matej1006
            https://duet3d.dozuki.com/Wiki/Duex_wiring_diagrams
            matej1006undefined 1 Reply Last reply Reply Quote 0
              matej1006 @deckingman
              @deckingman Yeah i know but which of to is gnd and which vcc on output for heater 1
                @matej1006 Sorry - I though you wanted to connect to the Duex board. Duet is here
                https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
                VCC is Vin (the one on the left in that diagram).
                  @deckingman no worry
