    documentation for /rr_* ?
    • arhiundefined
      arhi
      Is there any documentation for /rr_* URI's
      I see some on the fork's of DWC but I don't see a summary anywhere? Any apge where this is all documented?
      • chrishammundefined
        chrishamm administrators
        https://github.com/Duet3D/RepRapFirmware/blob/v3.01-dev/HTTP requests.md
        Duet software engineer
        • arhiundefined
          arhi
          Thanks, was looking for this one 😄
          any limit for rr_model? I see DWC is relentless calling it non stop? any "best practice here" not to overload the host for no reason?
            chrishamm administrators @arhi
            @arhi There is the seqs key in the standard rr_model request (which is called with flags=d99fn). I suppose you could omit the n parameter if you do not want to retrieve null values. If the numbers in seqs change, you know that a non-live field has been changed in the corresponding OM key.
