Heater Fault
Well I did the inevitable tried a voltage check on a fan terminal on my Duet WiFi, as you know the pins are quite close and I let the tester leads touch. Does this mean a new board or is there a work around?
probably possible to replace a fuse or mosfet on the board, ref this thread(s) maybe?
https://forum.duet3d.com/topic/15617/all-fans-don-t-work/
https://forum.duet3d.com/topic/1152/pwm-fan-controller-possibly-destroyed-advise-requested/or as a workaround, use one of the other fan outputs if free? (misleading title if the fan is the issue and the title says heater?)
