RRF 3.1.1 Connection Interrupted
I'm getting a nearly constant "Connection Interrupted" from my DuetWifi with RRF3.1.1.
DWC 3.1.1
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
Duet WiFi Server Version: 1.235/22/2020, 9:20:57 AM Connection established
5/22/2020, 9:20:51 AM Connection interrupted, attempting to reconnect...
HTTP request timed out
5/22/2020, 9:20:45 AM Connection established
5/22/2020, 9:20:41 AM Connection interrupted, attempting to reconnect...
Network error
5/22/2020, 9:20:36 AM Connection established
5/22/2020, 9:20:36 AM Connection interrupted, attempting to reconnect...
Network error
5/22/2020, 9:20:35 AM Connection established
5/22/2020, 9:20:35 AM Connection interrupted, attempting to reconnect...
Network error
5/22/2020, 9:20:27 AM Connection established
5/22/2020, 9:20:27 AM Connection interrupted, attempting to reconnect...
Network error
5/22/2020, 9:20:16 AM Connection established
5/22/2020, 9:20:13 AM Connection interrupted, attempting to reconnect...
5/22/2020, 9:20:00 AM Connection established
5/22/2020, 9:19:59 AM Connection interrupted, attempting to reconnect...
5/22/2020, 9:19:37 AM Connection established
5/22/2020, 9:19:37 AM Connection interrupted, attempting to reconnect...
@N7JTI Make sure the board has a good WiFi signal. See https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors
Alright, I added a wifi access point near the printer. The WIFI signal strength went from -59DBm t0 -48Dbm. It already seems a big improvement. I've had the printer in that location for several months and the Connection Interrupted behavior started with the switch to RRF 3.1. So it appears that RRF3 (or the other associated upgrades) can push a marginal Wifi connection over the edge to nearly unusable. Certainly the performance in this respect was a regression for me.
But, I've got a WiFI access point to put out there near the printer, so that is a solution in my case. Thanks for the help.
Before:
- WiFi -
Network state is active
Failed messages: pending 0, notready 0, noresp 7
WiFi firmware version 1.23
WiFi MAC address b4:e6:2d:53:12:0e
WiFi Vcc 3.38, reset reason Unknown
WiFi flash size 4194304, free heap 21816
WiFi IP address 192.168.1.106
WiFi signal strength -59dBm, reconnections 0, sleep mode modem
After:
- WiFi -
WiFi flash size 4194304, free heap 22080
WiFi signal strength -48dBm, reconnections 0, sleep mode modem
- WiFi -
