DUET 3 - PID control pressure sensor to run motor?
Hey,
is it plausible to connect a pressure sensor to the duet 3 with a pid control to run a stepper motor?cheers!
If it's the Z motor you want to control, then yes. See M951 and M594. Caution, this feature is experimental.
@dc42 said in DUET 3 - PID control pressure sensor to run motor?:
M951
I was actually looking to run an extruder.
@CJ-BRAVO said in DUET 3 - PID control pressure sensor to run motor?:
M951
That would require a modification to the M951/M594 code, to generalise to allow a different axis to be used. If the intention is to extrude with constant pressure, then a further modification would be needed to allow the PID controller to control motor speed instead of position.
I"f the intention is to extrude with constant pressure"
yes, that's the idea. -
so thats something in my range?
