network reboot after uploading STL
uploaded STL instead of GCODE
tried to delete the file - lost connectionlooks like only the network restarted as the machine did not lose home
refresh file list - lost connectiondunno if any useful info here but..
2:04 PM Error: Bad command: pA��Y@ Error: Bad command: �?sN Error: Bad command: �? Error: Bad command: pA��Y@ Error: Bad command: �? Error: Bad command: ? Error: Bad command: �? Error: Bad command: �B Error: Bad command: �?sN Error: Bad command: � Error: Bad command: �? Error: Bad command: pA��Y@ Error: Bad command: �? Error: Bad command: �B Error: Bad command: �? Error: Bad command: pA33�A Error: Bad command: �?sN 5/23/2020, 9:02:12 PM Connection interrupted, attempting to reconnect... HTTP request timed out 5/23/2020, 9:02:12 PM Connection established 5/23/2020, 9:02:13 PM Error: M25: Cannot pause print, because no file is being printed! 5/23/2020, 9:02:29 PM Upload of Z_nut.gcode successful after 1s 5/23/2020, 9:02:29 PM M32 "0:/gcodes/Z_nut.gcode" File 0:/gcodes/Z_nut.gcode selected for printing 5/23/2020, 9:02:36 PM Connection interrupted, attempting to reconnect... Network error 5/23/2020, 9:02:38 PM Connection established 5/23/2020, 9:03:02 PM Connection interrupted, attempting to reconnect... Network error 5/23/2020, 9:03:04 PM Connection established 5/23/2020, 9:03:10 PM Connection interrupted, attempting to reconnect... Network error 5/23/2020, 9:03:11 PM Connection established 5/23/2020, 9:03:18 PM Connection interrupted, attempting to reconnect... Network error 5/23/2020, 9:03:19 PM Connection established 5/23/2020, 9:03:25 PM M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet Ethernet 1.02 or later Board ID: 08DGM-9T6BU-FG3S4-6J9FD-3SD6Q-KVRBF Used output buffers: 3 of 24 (24 max) === RTOS === Static ram: 27980 Dynamic ram: 93984 of which 32 recycled Exception stack ram used: 544 Never used ram: 8532 Tasks: NETWORK(ready,276) HEAT(blocked,1224) MAIN(running,1816) IDLE(ready,80) Owned mutexes: === Platform === Last reset 28:34:38 ago, cause: software Last software reset at 2020-05-22 16:28, reason: User, spinning module GCodes, available RAM 8372 bytes (slot 1) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN Error status: 1c MCU temperature: min 30.7, current 35.6, max 37.4 Supply voltage: min 23.4, current 23.7, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max 0/337 Driver 1: standstill, SG min/max 0/395 Driver 2: standstill, SG min/max 0/434 Driver 3: standstill, SG min/max 0/1023 Driver 4: standstill, SG min/max not available Date/time: 2020-05-23 21:03:26 Cache data hit count 4294967295 Slowest loop: 456.16ms; fastest: 0.13ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 3.8ms, write time 651.9ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 111, MaxWait: 48238039ms Bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.0 Heater 1 is on, I-accum = 0.6 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "M190 S85.00" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 653.38ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 Interface state active, link 100Mbps full duplex === Filament sensors === Extruder 0 sensor: no data received 5/23/2020, 9:03:25 PM M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet Ethernet 1.02 or later Board ID: 08DGM-9T6BU-FG3S4-6J9FD-3SD6Q-KVRBF Used output buffers: 1 of 24 (24 max) === RTOS === Static ram: 27980 Dynamic ram: 93984 of which 32 recycled Exception stack ram used: 544 Never used ram: 8532 Tasks: NETWORK(ready,276) HEAT(blocked,1224) MAIN(running,1816) IDLE(ready,80) Owned mutexes: === Platform === Last reset 28:34:38 ago, cause: software Last software reset at 2020-05-22 16:28, reason: User, spinning module GCodes, available RAM 8372 bytes (slot 1) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN Error status: 1c MCU temperature: min 35.6, current 35.6, max 35.7 Supply voltage: min 23.7, current 23.7, max 23.7, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max not available Driver 1: standstill, SG min/max not available Driver 2: standstill, SG min/max not available Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Date/time: 2020-05-23 21:03:27 Cache data hit count 4294967295 Slowest loop: 1.17ms; fastest: 0.14ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms Bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.0 Heater 1 is on, I-accum = 0.6 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "M190 S85.00" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 4.38ms; fastest: 0.06ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 Interface state active, link 100Mbps full duplex === Filament sensors === Extruder 0 sensor: no data received
turn on ftp and delete it? or try
M30
if you know the filename already?
https://duet3d.dozuki.com/Wiki/Gcode#Section_M30_Delete_a_file_on_the_SD_card
@bearer after few network reboots right click delete did the job .. so everything is sorted out inside few minutes but I assumed maybe there's some useful data in the log so shared it..
