IR Sensor and trigger hight
  • I can't get the IR Sensor to Z0.
    Sensor is physically adjusted to be 1.5mm above nozzle. Offset -2/26.5 (x/y).
    Adjusting it to 1.5mm above nozzle gives me a trigger hight of 3.14mm but shall aim for 0.5 to 2.5mm according to DC42's page. Also, the vallue shown at 3.14mm trigger is 1000.
    I suspect, the probe is broken.
    Any help highly appreciated.
    PS: Duet3 RRF3.1.1 CoreX/Y
  • Moderator
    How do you have it setup in config.g?
    What is your bed surface?
  • Bed surface is a Geckotech.
    M558 P8 C"io3.in" H5 F120 T6000
    G31 P500 X-2 Y26.42 Z3.14
  • Moderator
    @observatoer said in IR Sensor and trigger hight:
    M558 P8
    You should be using M558 P1 for analogue probe mode.
  • @Phaedrux Tried P1 w same result. Saw a comment from DC42 to use Mode 8 for the probe on RRF3.
  • Moderator
    Does performance change with a piece of paper on the bed surface?
  • @Phaedrux No, I already tried different surfaces and they where detected equally.
  • Moderator
    so you've gone through this procedure?
    https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
  • @Phaedrux Yes, several times to confirm doing it right.
  • Moderator
    So what exactly is happening incorrectly? I'm not sure I understand from your first post.
    When you use G30 s-1 to measure the trigger height, what value do you get?
    When you use that value in G31 Z, are you able to move the nozzle to touch the bed at z0?
  • @Phaedrux
    Doing G30 S-1 gives me 3.14. Adding this to the config.g and home Z gives me Z=0, but the nozzle is esteem. 3.14mm above the bed.
    If I reajust the probe hight, the same thing happens, just with different values. Higher probe, lower Z and visa versa.
  • @observatoer
    Considering that you have the z-probe fine Tuned and configured. You commented that you have the problem when you do the homing. Is it possible that you do not use the z-probe to set z=0 and that there is this difference of one millimeter between the z-axis sensor and the z-probe?
    In my printer, with dual z axis, after home with micros witches every motor, I run a G30 command to set Z=0 with de Z-probe then I run a G32 command.
    It works well for me in reprap 3.1 on a duetWifi+Duex
  • Moderator
    Please post your full config.g and homeall.g / homez.g please
  • @Phaedrux Thanks for the support! Maybe, I figured it out but nor sure about the "how".
    M550 P"Duet 3" ; set printer name
    G21 ; Work in millimetres
    M575 P1 B57600 S1 ; Comms parameters for PanelDue
    M669 K1 ; select CoreXY mode
    ; Network & Logging
    M111 S0 ; Debug off
    M929 P"eventlog.txt" S0 ; Start logging to file eventlog.txt
    ; Axis and motor configuration
    M569 P0 S0 ; physical drive 0 goes backwards
    M569 P2 S1 ; physical drive 2 goes forward
    M569 P3 S0 ; physical drive 3 > Right goes backwards
    M569 P4 S0 ; physical drive 4 > Left Front goes backwards
    M569 P5 S0 ; physical drive 5 > Left Back goes backwards
    M584 X1 Y2 Z3:4:5 E0 ; set drive mapping: Achtung. Z Motoren P3=Z3, P4 = Z4 und P5=Z5!! Sonst funktioniert Leveling nicht.
    M350 X16 Y16 E16 I1 ; configure microstepping with interpolation
    M350 Z16 I1 ; z axis isolated
    M92 E830 ; set steps per mm Extruder
    M92 X191.883 Y191.883 ; set steps per mm (0.9/16T=200s/mm) calibrated PLA: 190.9286
    M92 Z3200 ; z axis isolated
    M203 X24000 Y24000 Z900 E8000 ; set maximum speeds (mm/min)
    M201 X1000 Y1000 Z40 E1300 ; set accelerations (mm/s^2)
    M906 X1900 Y1900 Z1600 E650 I5 ; set motor currents (mA) and motor idle factor in per cent
    M566 X1000 Y1000 Z150 E3000 ; Maximum jerk speeds mm/minute / Jubilee
    M84 S600 ; Set idle timeout
    ;Pressure Advance
    M572 D0 S0.05 ; set pressure advance for extruder 0. Direct Drive recomendation = 0.025
    ;Leadscrew locations
    M671 X-10:-10:333 Y22.5:277.5:150 S7.5 ; Front left, Rear Left, Right S7.5 is the max correction - measure your own offsets, to the bolt for the yoke of each leadscrew
    M208 X0 Y0 Z-2 S1 ; set axis minima
    M208 X305 Y305 Z315 S0 ; set axis maxima
    M558 P8 C"io3.in" H5 F120 T6000 ; Changed from Mode 1 to Mode 8 for IR / set Z probe type to unmodulated and the dive height + speeds
    G31 P500 X-2 Y26.42 Z1.45 ; set Z probe trigger value, offset and trigger height (DC42)
    M557 X0:295 Y0:295 S70 ; define mesh grid
    M574 X1 S1 P"io1.in" ; configure active-high endstop for low end on X via pin io1.in
    M574 Y1 S1 P"io2.in" ; configure active-high endstop for low end on Y via pin io2.in
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    ; Heater & Fan
    M308 S0 P"temp0" A"Heat Bed" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
    M307 H0 B1 S1.00 ;enable bang-bang mode for the bed heater and set PWM limit
    M308 S1 P"temp1" A"Slice Hotend" Y"thermistor" T500000 B4723 C1.19622e-7 ; Slice Thermistor: configure sensor 1 as thermistor
    ; on pin temp1
    M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
    M307 H1 B0 S1.00 ; set bang-bang mode for heater
    M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency >> Heatsink Fan
    M106 P0 S0 H1 T45 ; set fan 0 value. Thermostatic control is turned on.
    M950 F1 C"out9" Q500 ; create fan 1 on pin out9 and set its frequency. >> Part Fan
    ;;M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
    M106 P1 S1 H1 T45
    ;Probe points
    M557 X20:275 Y30:275 P3
    M563 P0 S"Mosquito Magnum" D0 H1 F0 ; define tool 0
    ;M98 P"config-user.g" ; Load custom user config if one exists.
    ;M501 ; Load saved parameters from non-volatile memory
    ;G29 S1
    ; Note: you will need to tune the bed heater, and both extruder cartridges before printing.
    ; See the following link for more details. https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
    ; homeall.g
    ; called to home all axes
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat May 16 2020 15:05:51 GMT+0200 (CEST)
    G91 ; relative positioning
    G1 H1 X-305 Y-305 F1800 ; move quickly to X or Y endstop and stop there (first pass)
    G1 H1 X-305 ; home X axis
    G1 H1 Y-305 ; home Y axis
    G1 X5 Y5 F6000 ; go back a few mm
    G1 H1 X-305 F360 ; move slowly to X axis endstop once more (second pass)
    G1 H1 Y-305 ; then move slowly to Y axis endstop
    G1 H1 Z-305 F360 ; move Z down stopping at the endstop
    G90 ; absolute positioning
    G92 Z1.60 ; Remark: Adjuted from Z0 to Z1.60 // set Z position to axis minimum (you may want to adjust this)
    ;G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
    G1 Z5 F100 ; lift Z relative to current position
    ; homez.g
    ; called to home the Z axis
    G1 H2 Z5 F300 ; lift Z relative to current position
    G1 H1 Z-305 F300 ; move Z up until the endstop is triggered
    G92 Z1.60 ; set Z position to axis minimum (you may want to adjust this)
  • Moderator
    Your homing files are using end stops to home Z and not the probe.
    These sections should be replaced with
    G1 X100 Y100 F6000 ; move probe to center of the bed. Adjust as needed.
    G30 ; probe the bed to establish z0
  • @Phaedrux YES! This is the solution. Thank you very much 😳 👍
