    Bed probing issues coords not valid
    295
    • joehsmashundefined
      joehsmash
      im just trying to get this thing dialed in.
      i had to move my home location to the centre of the bed, with my new flexplate the IR sensor was reading off the flex plate and was giving errors,
      i have zeroed down my axis movements,
      x -110 min max 110
      y-122 min max 122
      now when i execute g1 x0 y0 the print head goes directly to the middle of the print bed.
      when i set my mesh coords it saying that these coords arent valid when i run a g32, when clearly they are. IE if i command the print head to go to any of these coords it will go.
      5/25/2020, 1:38:25 AM: : Warning: Skipping grid point (90.0, -110.0) because Z probe cannot reach it
      Warning: Skipping grid point (90.0, -10.0) because Z probe cannot reach it
      5/25/2020, 1:39:25 AM: G1 X90 Y-10
      5/25/2020, 1:41:54 AM: Upload of config.g successful after 0s
      5/25/2020, 1:42:05 AM: Failed to maintain connection to 192.168.1.44: CORS request failed
      5/25/2020, 1:43:38 AM: : Warning: Skipping grid point (90.0, -110.0) because Z probe cannot reach it
      Warning: Skipping grid point (110.0, -110.0) because Z probe cannot reach it
      Warning: Skipping grid point (110.0, -90.0) because Z probe cannot reach it
      Warning: Skipping grid point (90.0, -90.0) because Z probe cannot reach it
      here is my config.g
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 11 2020 00:13:10 GMT-0600 (Mountain Daylight Time)
      M550 P"JoehBo3D" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P3 S0 ; physical drive 3 goes forwards
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
      M671 X-160:160 Y0:0 S1 F1 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      M208 X-110:110 Y-122:122 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
      M350 X16 Y16 Z16 E16 I1 ; configure microstepping without interpolation
      M92 X80 Y80 Z800 E790 ; set steps per mm
      M566 X1020 Y1020 Z24 E3000 ; set maximum instantaneous speed changes (mm / min)
      M203 X6000 Y6000 Z180 E8000 ; set maximum speeds (mm / min)
      M201 X6000 Y6000 Z100 E3000 ; set accelerations (mm / s ^ 2)
      M906 X935 Y935 Z935 E935 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-110 Y-122 Z0 S0 ; set axis minima
      M208 X110 Y122 Z203 S1 ; set axis maxima
      M574 X1 Y1 S1 ; set active high endstops
      M574 Z1 S2 ; set endstops controlled by probe
      M558 P1 H3 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P600 X-24 Y-2 Z0.120 ; set Z probe trigger value, offset and trigger height
      M557 X-110:110 Y-110:110 S20 ; define mesh grid
      M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4388 R4700 ; set thermistor + ADC parameters for heater 1
      M143 H1 S300 ; set temperature limit for heater 1 to 300C
      M106 P0 S0 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S1 I0 F500 H1:1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M501 ;
      here is my BED.g
      ; bed.g
      G28 ; home
      G30 P0 X-110 Y0 Z-99999 ; probe near a leadscrew, half way along Y axis
      G30 P1 X60 Y0 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
      G29 ; probe the bed and enable compensation
      here is my HOMEALL.g
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 11 2020 00:13:11 GMT-0600 (Mountain Daylight Time)
      G91 ; relative positioning
      G1 H1 X-110 Y-122 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-110 Y-122 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G90 ; absolute positioning
      G1 X0 Y0 F6000 ; go to first bed probe point and home Z
      ;G91 ; relative positioning
      ;G1 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      thanks for looking.
      Joeh
      • catshowundefined
        catshow
        I just ran into the same problem. I am trying to probe my bed. It looks like the probing is using the probe location for coordinates on the minimal side, but then uses the print head location on the maximal size, and it will skip the last probe.
        The G30 command would probe outside of the print boundaries.
        It seems like bed leveling should always use the probe location when determining where it is probing and whether it is out of bounds or not.
        • aidarundefined
          aidar
          In M557 you have to put probe coordinates, not nozzle coordinates.
          For exampe, your first warning : your x max is 110 and probe offset in x is -24. That means, probe can reach max x 86. So it can not reach x 90 and gives warning.
          joehsmashundefined 2 Replies Last reply Reply Quote 0
            joehsmash @aidar
            @aidar ohhh i totally forgot to factor in my probe offset!
            This is my brain at 2am!
            Ill get back to you
              joehsmash @aidar
              @aidar i have made the adjustments with my probe taken into account and im sure ive got this correct.
              G31 P600 x-2 Y-24 Z0.120 ; set Z probe trigger value, offset and trigger height
              M557 X-108:110 Y-98:122 S20 ; define mesh grid
              how my printer works, x-110 y-122 is the front corner of the machine the bed (y) axis moves front to back, back corner is x110 y122 and obviously 0,0 is smack in the middle of my bed.
              currently the probe is on the front side of the hotend, so if the nozzle is sitting at x -110 the probe is actually probing off of the buildtak system, so when i adjust the mesh to y-108 ( y offset is -24 infront of the hotend) it probes the buildtak just perfect.
              so now when i run g32 im still getting errors, even though the probe physically has access to all of them and can see them.
              Warning: Skipping grid point (-88.0, 102.0) because Z probe cannot reach it
              Warning: Skipping grid point (-68.0, 102.0) because Z probe cannot reach it
              Warning: Skipping grid point (-48.0, 102.0) because Z probe cannot reach it
              Warning: Skipping grid point (-28.0, 102.0) because Z probe cannot reach it
              Warning: Skipping grid point (-8.0, 102.0) because Z probe cannot reach it
              Warning: Skipping grid point (12.0, 102.0) because Z probe cannot reach it
              Warning: Skipping grid point (32.0, 102.0) because Z probe cannot reach it
              Warning: Skipping grid point (52.0, 102.0) because Z probe cannot reach it
              Warning: Skipping grid point (72.0, 102.0) because Z probe cannot reach it
              Warning: Skipping grid point (92.0, 102.0) because Z probe cannot reach it
              Warning: Skipping grid point (92.0, 122.0) because Z probe cannot reach it
              Warning: Skipping grid point (72.0, 122.0) because Z probe cannot reach it
              Warning: Skipping grid point (52.0, 122.0) because Z probe cannot reach it
              Warning: Skipping grid point (32.0, 122.0) because Z probe cannot reach it
              Warning: Skipping grid point (12.0, 122.0) because Z probe cannot reach it
              Warning: Skipping grid point (-8.0, 122.0) because Z probe cannot reach it
              Warning: Skipping grid point (-28.0, 122.0) because Z probe cannot reach it
              Warning: Skipping grid point (-48.0, 122.0) because Z probe cannot reach it
              Warning: Skipping grid point (-68.0, 122.0) because Z probe cannot reach it
              Warning: Skipping grid point (-88.0, 122.0) because Z probe cannot reach it
              Warning: Skipping grid point (-108.0, 122.0) because Z probe cannot reach it
                joehsmash
                got it sorted,
                instead of making adjusting the y negative position i had to adjust the positive position (at the back of the bed...) which makes no sense to me.
                M557 X-108:110 Y-110:198 S100 ; define mesh grid
                all is working well with the probing movements.
                Joeh
                aidarundefined 1 Reply Last reply Reply Quote 0
                • aidarundefined
                  aidar @joehsmash
                  @joehsmash said in Bed probing issues coords not valid:
                  You got it right. Your Ymax is 122 and probe offset Y-24. That means, probe can reach Y98, not more. So yes, you had to adjust mesh area at positive side.
                  And look at your last post: M557 X-108:110 Y-110:198 S100. I hope that Y 198 is typo, because it should be 98, not 198.
                    joehsmash
                    It was indeed a typo.
                    thanks for your help on this one, now on to to the last issue, which i am about to post on..
