Mendel90 Dibond with DuetWifi
  • Spent the weekend getting my Mendel90 up and running with my Batch 4 DuetWifi. Coming from RAMPS & OctoPi it's been an interesting couple of days. I love the all in one WiFi web interface and the IR bed peobe. I'm probably going to set up a RaspberryPi Zero with PiCam as a WiFi camera feed, perhaps with capture triggered by IO from the DuetWifi (not sure what signals yet…). Hopefully I'll find time in the week to try a test print!
    Edit:
    Other future upgrades will hopefully include
    For anyone else who is trying to get a Mendel90 (or any other cartesian printer) up and running I'm more than happy to share my experiences!
  • Some photos…
    Thanks for the pics and write-up. I am not sure the easiest way to add a M42 command at each layer change to trigger a camera… Depends on the slicer. Will the Raspi accept a simple pin toggling from low to high or vice versa to trigger a camera?
  • I wrote a simple python script to go through a gcode file, look for G1 Z (layer change) and add a line after starting M567 (mixing ratios) in order to get my 300 colour thingy. One could use the same process to add a M42 command.
    HTH
    @T3P3Tony:
    I'm not sure if there is already a userspace application for this purpose, but I wrote a similar program about a year ago for a Freescale ARM CPU that emulated a key event when a GPIO signal changed. If you're not afraid of writing a small C program, this link might help: http://elinux.org/GPIO#Enable_GPIO_from_application_space
    Ian, yes post processing the gcode is certainly a way to do it. I think Cura has the ability to add layer change commands within the slicer (on my phone right now so can't check).
    BTW DebugBear, I am still such a fan of nophead's design for a Cartesian printer!
  • My plan was to use a simple GPIO pin trigger, with a script/program running on the raspi monitoring the pin and controlling the capturing of images. I've had some experience with this playing with my PiCam already.
    I spent a long time considering all the reprap DIY/self-build models before settling on the Mendel90. And Nophead's kit was excellent value considering the pre-cut dibond sheets.
    I am also keen to play with other styles of printers though, and have love the way deltas move when printing. Just need to find the time…
  • When using Slic3r as slicer, you can add individual commands on layer change.
  • @Pumlux:
    Well blow me down, so you can. I've been using Slic3r for ages but my eyes never got that far. G codes on tool changes too - now that could be useful. Thanks for pointing this out.
