New LDO Motors on X & Y - now noisy
Hey team.....
Since installing 2 x new Prusa STD LDO motors on X and Y the X and Y moments have become extremely noisy. The previous motors were Geetech 1.8a , and extremely quiet.
I have tried everything , and nothing I can do quietens them down.
- variance current anywhere from 450 to 800
- Changing micro-steping to 256, with 32 and 128 in the middle
They sound "dry" - its awful
Build is a X=Zaribo MK3 with rails on X, Y and Z
TIA - this i driving me potty
RayCONFIG.G below
; Configuration file for Duet Maestro (firmware version 2.03)
; generated by RepRapFirmware Configuration Tool v2.1.4 on Tue Dec 24 2019 01:03:43 GMT+1300 (New Zealand Daylight Time); General preferences
M550 P"My Zaribo" ; set printer name
M918 P1 E4 F2000000 ; configure direct-connect display
M574 X1 Y1 S1 ; set active high endstops
M574 Z1 S2 ; set endstops controlled by probe
M552 P192.168.0.66 S1 ; enable network and set IP address
M553 P255.255.255.0 ; set netmask
M554 P192.168.0.6 ; set gateway
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives (Steves Settings)
;M584 X0 Y1 Z2:4 E3 P3 ; stepper driver mapping
M671 X-38:293 Y100:100 S10 ; Z Lead Screw Leveling probe Point Mapping
;M671 X30:235 Y100:100 S2 ; Z Lead Screw Leveling probe Point Mapping
M569 P0 S0 ; Drive 0 goes reverse [ X Axis ] [ S0 = Rev / S1 = FWD ]
M569 P1 S0 ; Drive 1 goes reverse [ Y Axis ]
M569 P2 S0 ; Drive 2 goes reverse [ Z Axis - LT ]
M569 P4 S0 ; Drive 4 goes reverse [ Z Axis - RT ]
M569 P3 S1 ; Drive 3 goes Norm [ E0 ]
M350 X16 Y16 Z16:16 E16 I1 ; Configure microstepping with interpolation
;M92 X1600 Y1600 Z400:400 E830 ; Set steps per mm
M92 X100.30 Y100.250 Z400:400 E830 ; Set steps per mm
M566 X450 Y450 Z30:30 E600 ; [ JERK Settings ] Set maximum instantaneous speed changes (mm/min)
M201 X1000 Y1000 Z200:200 E1250 ; Set ACCELERATIONS (mm/s^2)
M203 X6000 Y6000 Z720:720 E2000 ; Set MAX SPEEDS(mm/min)
M906 X650 Y650 Z400:400 E600 I30 ; Set motor CURRENTS (mA) and motor idle "power saving" decrease factor as percentage [ I30=30% ]
M84 S30 ; Set idle timeout;M569 P0 S1 ; physical drive 0 goes forwards
;M569 P1 S1 ; physical drive 1 goes forwards
;M569 P2 S1 ; physical drive 2 goes forwards
;M569 P3 S1 ; physical drive 3 goes backwards
;M584 X0 Y1 Z2 E3 ; set drive mapping
;M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
;M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm
;M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
;M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
;M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
;M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
;M84 S30 ; Set idle timeout; Axis Limits
M208 X245 Y210 Z200 S0 ; set axis maxima; Z-Probe
M558 P9 H5 F350 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-20 Y-35 Z4.552 ; set Z probe trigger value, offset and trigger height
M557 X-5:260 Y-10:210 S35 ; define mesh grid
;M557 X5:250 Y0:210 S40 ; define mesh grid
;---------------------------; *** Bed H0
M305 P0 T100000 B4138 R2200 ; set thermistor + ADC parameters for heater 0
M143 H0 S120 ; set temperature limit for heater 0 to 120C; *** Extruder / HotEnd H1
M301 H1 P10.1, I0.326, D39.2 B0 ; H1 Hotend E0 use PID || Last Auto-tune results 260C --> [ P11.0, I0.391, D41.0 | P10.1, I0.326, D39.2 ]
M305 P1 T100000 B4725 R2200 ; Set thermistor + ADC parameters for heater 1
M143 H1 S275 ; Set temperature limit for heater 1 to 275C
;M307 H1 A254.4 C144.6 D4.4 B0 ; Saves this models parameters || B0 = Use PID / B1 = Bang Bang || PWM 1.00 || No more M301 4 H1 after this; Heaters
;M305 P1 T102000 B4388 R4700 ; set thermistor + ADC parameters for heater 1
;M143 H1 S240 ; set temperature limit for heater 1 to 280C; Fans
;M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
;M106 P1 H100:101 T50:55 L0.3
M106 P2 S1 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off; Tools
What VIN voltage are you using, and what's the specification of the new motors?
Hi,The VIN Voltage is 24V
the motors are the default Prusa X and Y motor, unfortunately the part number on the motors does not yield any results for specification.
It's gone from a really nice quiet printer to now I cannot run it whilst the kids are in bed
Cheers
Ray
@Kiwi3D There was this thread recently about noisy LDO Prusa motors: https://forum.duet3d.com/topic/15121/is-it-normal-for-motors-to-vibrate-and-hiss-at-standstill
