    Solved Manual level with a z probe
    157
    • joehsmash
      joehsmash last edited by
      I want to manually mesh level my bed ignoring my z probe cuz its a piece of junk.
      How can i do this? I dont have leveling screws so I can't use the assistant.
      • chrishamm
        chrishamm administrators last edited by
        Set the Z probe type to 0 via M558, probe the bed, and restore the prior Z probe configuration. To dio this, change your bed.g to something like
        M558 P0 ; turn off Z probe
        G29 S0 ; probe the bed
        M558 P1 ; provided P1 is in your config.g too
        Make sure to put a M557 code with the correct mesh size in config.g before you run G32 / True Bed Levelling.
        Duet software engineer
        joehsmash 2 Replies Last reply Reply Quote 0
        • joehsmash
          joehsmash @chrishamm last edited by
          @chrishamm great i will try this, i didnt think to do that because the probe info is located in the config, and it has to be reloaded everytime i change something!
          Ill try in the am!
          fcwilt 1 Reply Last reply Reply Quote 0
          • fcwilt
            fcwilt @joehsmash last edited by
            @joehsmash
            I have a file called configprobe.g that, as you might expect, configures my Z probe.
            I call this file using M98 as needed.
            Having a file like this means it can be called from another .g file, or a macro, etc.
            • joehsmash
              @chrishamm just added to my bed.g file it brings up the adjustment screen but lets say i adjust the nozzle down 5mm the button just sits there and hangs, and will not let me go any lower, actually any button i press it does the same thing, just hangs.
              just has the a ever ending refreshing circle on it.
              bed.g
              ; bed.g
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon May 11 2020 00:13:10 GMT-0600 (Mountain Daylight Time)
              G28 ; home
              G30 P0 X-110 Y0 Z-99999 ; probe near a leadscrew, half way along Y axis
              G30 P1 X100 Y0 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
              G29 ; probe the bed and enable compensation
              config.g
              M550 P"JoehBo3D" ; set printer name
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P3 S0 ; physical drive 3 goes forwards
              M569 P4 S1 ; physical drive 4 goes forwards
              M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
              M671 X-160:160 Y0:0 S1 F1 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
              M208 X-110:110 Y-122:122 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
              M350 X16 Y16 Z16 E16 I1 ; configure microstepping without interpolation
              M92 X80 Y80 Z800 E790 ; set steps per mm
              M566 X1020 Y1020 Z24 E3000 ; set maximum instantaneous speed changes (mm / min)
              M203 X6000 Y6000 Z180 E8000 ; set maximum speeds (mm / min)
              M201 X6000 Y6000 Z100 E3000 ; set accelerations (mm / s ^ 2)
              M906 X935 Y935 Z935 E935 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X-110 Y-122 Z0 S0 ; set axis minima
              M208 X110 Y122 Z203 S1 ; set axis maxima
              M574 X1 Y1 S1 ; set active high endstops
              M574 Z1 S2 ; set endstops controlled by probe
              M558 P1 H3 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
              G31 P600 x-2 Y-24 Z0.120 ; set Z probe trigger value, offset and trigger height
              M557 X-108:108 Y-110:98 S100 ; define mesh grid
              M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
              M305 P1 T100000 B4388 R4700 ; set thermistor + ADC parameters for heater 1
              M143 H1 S300 ; set temperature limit for heater 1 to 300C
              M106 P0 S0 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M106 P1 S1 I0 F500 H1:1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M501 ;
                May I ask what firmware and DWC version you're using?
                joehsmash 1 Reply Last reply Reply Quote 0
                • joehsmash
                  joehsmash @Phaedrux last edited by
                  @Phaedrux
                  M115: FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
                  Duet Web Control 2.0.0-RC3
                  Electronics: Duet WiFi 1.02 or later
                  Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05.1 (2020-02-09b1)
                  Duet WiFi Server Version: 1.2
                    Phaedrux Moderator @joehsmash last edited by Phaedrux
                    @joehsmash said in Manual level with a z probe:
                    I suggest you update to at least DWC 2.0.7 for fw 2.05.1
                    Your wifi server is out of date as well by the way.
                    https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1
                    • joehsmash
                      joehsmash @Phaedrux last edited by joehsmash
                      @Phaedrux YASSSSSSSSS
                      that totally fixed it.
                      the manual level fixed all the issues... now to get to perfecting my first layer again!
                      instead of the bed being off by a whopping 1.5m its only a 0.250 deviation off of a 0.2 thickness feeler!
                      loving it!
                      how do i mark as solved?
