failed to enable endstops
i have a duet 2 with a duex5 and have my endstop switches are set up as NC. i have the red lights for the X and Y and they turn off when i press the switches, if i try to home X it lifts the Z and then gives the failed to enable endstops error. the endstop readouts say n/a for X and Y and Z says YES. on a side note i also cant get my BL tough to deploy. ive gone over the setting up z probe and connecting endstop switches pages several times and cant figure what im missing. this is the second duet ive set up, things seem to match my other printer but maybe im thinking about it too hard and missing something.
i have DWC2 and Firmware 3.1.1
my config
; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat May 23 2020 19:12:15 GMT-0700 (Pacific Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"1M" ; set printer name ; Network M551 P"" ; set password M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes forwards X M569 P1 S1 ; physical drive 1 goes forwards RY M569 P2 S0 ; physical drive 2 goes forwards RZ M569 P3 S1 ; physical drive 3 goes forwards E M569 P5 S1 ; physical drive 5 goes forwards LY M569 P6 S0 ; physical drive 6 goes forwards LZ M584 X0 Y1:5 Z2:6 E3 ; set drive mapping M350 X16 Y16:16 Z16:16 E16 I1 ; configure microstepping with interpolation M92 X114.29 Y114.29:114.29 Z400:400 E420.00 ; set steps per mm M566 X200.00 Y50:50 Z12:12 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X5000.00 Y3200:3200 Z500:500 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y30:30 Z20:20 E250.00 ; set accelerations (mm/s^2) M906 X1000 Y1700 Z1200 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X1400 Y800 Z900 S0 ; set axis maxima ; Endstops M574 X1 Y1 S1 ; set active high endstops M574 Z1 S2 ; set endstops controlled by probe ; Z-Probe M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch M558 P9 H10 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P25 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X5:1350 Y5:750 S75 ; define mesh grid ; Heaters M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined -
Your config.g hasn't been updated to be compatible with RRF3.
@Phaedrux ahh i see. time to learn again.
It may be easier to use the web configurator to create a new config file set compatible with RRF3 and then compare it to your existing config to see how it's changed. Some things may still need to be manually configured.
