Duet API return current M557 probe points
  • undefined
    nickpm
    Does anyone know if there is a query I can send to the machine to return the current X and Y ranges for the M557 command. So if in my config.g I have a M557 X0:100 Y0:100 S20 and then at some point I send the duet a M557 X0:50 Y0:50 S10 is that saved somewhere in the status type 1, 2, or 3 response?
    • undefined
      Using RRF 3.1.1:
      m409 k"move.compensation.probeGrid"
      {"key":"move.compensation.probeGrid","flags":"","result":{"radius":140.0,"xMax":140.0,"xMin":-139.9,"xSpacing":28.0,"yMax":140.0,"yMin":-139.9,"ySpacing":28.0}}
      • undefined
        nickpm
        This post is deleted!
        undefined 1 Reply Last reply 1 Jun 2020, 19:20 Reply Quote 0
        • undefined
          dc42 administrators @nickpm
          @nickpm said in Duet API return current M557 probe points:
          How do I actually send that request to get a response back? I can't use :
          rr_gcode?gcode=M409 k"move.compensation.probeGrid"
          because that doesn't send anything.
          To send it as a GCode command over HTML you need to URL encode it, for example replacing spaces by %20.
          Should I be using rr_model?
          Yes, use: rr_model?key=move.compensation.probeGrid&flags=
          • undefined
            nickpm
            So I'm sending this now:
            /rr_model?key=move.compensation.probeGrid&flags=d99vn and I'm getting a failed response that just says E
            • undefined
              nickpm
              Nevermind I fixed it, was a client issue.
              1 out of 6
