    G31 "Trigger value" what is it good for
    • JoduWeiundefined
      JoduWei
      All I can find is "Pnnn Trigger value". But what is it good for?
      • fcwiltundefined
        fcwilt
        I'm not sure I understand your question.
        The firmware needs to know what value is output by the Z probe when the Z probe is triggered.
        The manufacture of the Z probe would normally tell you what value to use.
          Most probes are like switches, either on or off, so a value of 1000 or 0. But analogue probes are different and you can get a range of values between 1000 and 0 and that can be used to detect when the probe is getting close to the bed and start to slow down.
          • giostarkundefined giostark referenced this topic
